JCviggen's misano B7 RS4 - work in progress
Hello everyone.
I’ve registered here because this board struck me as the most technically minded without too much BS. Hopefully my initial impressions will turn out to be correct ;D
Anyway. Long story long:
I’ve bought a B7 RS4. In Moscow, Russia. I work and live here even if I’m Belgian originally. The mere fact that I bought it in Russia complicates things a little, insofar that you don’t have many used RS4s to choose from and none of them are likely to be in perfect condition. I also have a C5 RS6 which I’ve been driving for the past 4 years so I’m no stranger to all the faults and aggravation that is part of owning these things.
I had been looking at 997 turbos but the local currency collapsing led to all the good ones being snapped up before I had the funds available, and now they’re somewhat overinflated. So I went to plan B of getting a B7 RS4 I had always wanted as a “fun” car with the future purpose of turning it into a Nordschleife-going track car when I’m visiting home. Until then I’ll use it for regular stuff here in Moscow.
I figure it should be good fun to have a high revving NA on track, and back in the day with my turbo volvo blowing off boost hoses and other turbo issues on track did get on my nerves. It’s also very drivable in the wet, which is a bonus given the climate there. Maybe I’ll fit some KW v3, take all the seats out and replace them with light racing buckets. Add some proper brake pads on 380mm rotors and it should be a capable car to both use as a track vehicle and a daily driver when I’m visiting home. Of course the precats will get ditched and a suitable map flashed into it but I’m not totally sold on aftermarket exhausts yet.
So I test drove a blue B7 which had a nice owner and had bucket seats but it was slow with a capital S. I knew this could be caused by some pretty basic little things but it didn’t sit well with me anyway. Tested the red one sans buckets (from the passenger seat, something of a mistake but OK) and it performed how I expected a fairly healthy RS4 to perform. So I bought that one. Also because its paint was nice and new and the owner had even gone so far to replace the headlights, grille and fogs because the old ones were faded. He gave me the old ones by the way, undamaged. So I might sell them for a few bucks at some point.
Of course, it did have some issues. For a start it would go into limp mode after a getting on it a couple of times and it was triggering EPC, MIL and ESP warning lights in various combinations. I had my mechanic look at it over the new year holidays, and I brought a new MAF with me from Europe just in case. Just before I was coming back it was diagnosed with a faulty throttle body causing most of the problems. I didn’t have time to get a new one on the plane with me, but found a used one to tie me over. It also got new spark plugs (though they fitted Bosch made 101905631H, not the exact p/n for the RS4 but apparently an alternative) and 8 new COPs. Those seemed excessive to me given the circumstances but hey.
Anyway, after maintenance it performs as a stock car should and it’s not throwing any codes anymore. It did the 3-8K “Arthur” test in 7.95s on the tach and 8.25s in VCDS. I only did it once because conditions were less than ideal. It was very cold (about -8C) and the roads were slippery so it literally was crabbing over the road when the power kicked in properly above 5600rpm. Slowing back down from 100 was interesting as well, good thing it was a wide dual lane road.
Vid http://www.greenringer.net/various/arthur.mp4
So the baseline is all right. For those interested in MAF readings, I was seeing a maximum of 166 g/s at 8000 in 3rd gear. Keep in mind it was VERY cold so in more normal air densities this would be a bit lower. I do notice a VERY big kick at 5600 or so when the airbox flap opens. It feels pretty slow until that point, I wonder if the difference becomes more and more noticeable the colder it is. After all, the throttle is more restricted at lower revs when it’s cold.
Biggest unresolved issue: the gearbox. The first 3 gears have worn synchros, 3rd worst of all. A transmission fluid change improved things quite a lot but there’s no hiding the fact that the synchros are toast. Downshifting from 4th into 3rd cannot be done without grinding. I’ve tried everything. On the way up it works a little better but every now and then a small grind still occurs. I’m basically avoiding 3rd most of the time now. 2nd to 4th and vice versa. Box is plenty short so it works all right for getting around town but no fun otherwise.
If I shift slow enough I can do 1-2-3 to redline without too much drama but this is as good as it gets: http://www.youtube.com/watch?v=GsCsJ6jM12I
Normally this would be a pretty easy thing to solve right? Ship the box to JHM or buy their rebuild kit. Except, I’m in Russia. My mechanic, as good as he has proven himself so far, won’t touch the insides of a gearbox. They all seem to think it’s some sort of black magic device nearly nobody is qualified to even look at. I’m not finding any big reputable company I could trust here either. Shipping stuff this big abroad is mission impossible within reasonable financial limits.
I have located a used box within Russia which I can get for about 1200$. It’s in Siberia (sigh) but as it’s within the country it can get here in a week without needing the bureaucracy. Trouble is, what are the odds of a used gearbox from Siberia being any better? As far as I can tell, not TOO many of these cars develop terminal synchro issues, so my odds might be about 50/50? Still undecided. I might get it done when I drive it to Europe in summer but I’m kind of aching to get it done sooner.
Smaller issue: since I got it back it is very rough/hesitating when cold at low revs. In particular, steady low throttle cruising at 50mph or so, it’s shaking all over the place. No misfire codes though. It improves a lot when the car is warm, still at very low revs it feels a bit rough sometimes but otherwise very drivable. Maybe the used throttle body I bought is simply on its way out as well? In a few weeks I should get the new one (ordered a GM part by the way, Audi price is ludicrous… 400$ vs 1100$)
This morning, a cold start at -14C also exposed the starter solenoid’s dislike for the cold. Worked all right the rest of the day. No biggie that.
Hopefully over time this thread will be about how much I like the car and the improvements that are made, rather than how much I want to set it on fire.
