Hi guys,
I’ve applied the ECU Tune a couple of months ago to my Audi S6, in addition to the TCU tune which was on previously, and I just wanted to share some experiences and see if its consistent with what others are having. (I’ve also emailed JHM and waiting to hear back)
POSITIVES
- Firstly the torque at lower rpm is much stronger and the car feels like it pulls a lot harder through to 4,000rpm.
- The power feels much stronger and the car is more eager.
- Throttle feels more sensitive (might just be the torque)
- The SAI delete option has removed some of the cold start up jerkiness that I was previously experienced. Was only minor anyway.
NEGATIVES
- My biggest issue: I did a track day a couple of weeks ago and although the car felt strong, in manual mode, the transmission does not let me shift UP on anything more than a light (1/4) throttle. It then just auto shifts up when it hits the red line. Sometimes I click the UP paddle multiple times and its only 5 seconds later that it shifts up, or not at all. This obviously makes it very difficult to drive confidently on track when I’m not in full control of the car as I’m not always sure what gear i’m in. Also its a bit dangerous as I don’t want to be bouncing off the red line mid corner. In day to day driving and with very light throttle it will let me manually shift up.
- In Standard Drive mode the shift with light throttle (even feather light thrtottle) occurs at higher rpm than I’d like it. So it shifts at say 3-3,500rpm with very light throttle, rather than at 2-2,500rpm. Not the biggest issue in the world and I can live with that.
- In Standard Drive mode (wife driving mode), when if you do anything more than light throttle the shift point moves higher and is at 4-4,500rpm and if I leave ESP on there is a THUMP when it goes to change from 2nd to 3rd gear and the car cuts power (like it has shifted to neutral) at the point of the shift. The power then comes back a second or two later. The ESP light does not come on, but if I turn ESP off this issue isn’t there. Regardless I think the shifts are much too hard in standard Drive mode. They really Thump very hard. I think it may be something to do with the shift being at around 4,000rpm at Peak torque. The shifts are 7,000rpm are faster and smoother than those at 4,000 rpm which are very violent.
Please could I get your thoughts and experiences? Same as mine, or am I unique? Thanks guys.
