I just cant get past how sexy that exhaust looks.
ok so a few things.
Your exhaust can grow or expand quite a bit when it heats up. Generally it will expand length wise. So what I usually do when I help install exhaust systems is to take and before I bolt down the exhaust I expand the exhaust back about an inch to see what might hit under expansion. Doing this will let you know if your hot exhaust tips will hit anything. If I do find the tips hit I try to make adjustments or do a small bit of trimming on the defuser
So my tips would be. Check the range of the exhaust expansion and consider doing some trimming on the rear defuser. Its also a good idea to put a swing lock on your rear exhaust mounting arms. This helps stop the side to side swing of the exhaust.
If you dont want to do any rear trimming then you can consider putting exhaust heat tape on the spots on the body that come in contact. From there paint those sections of heat tape the approperate color to match the trim.
Also compugeek had some real solid suggestions that would work as well.
