Okay, so the point of this is just my personal experience on all the JHM parts I have. I’ve acquired many over the past 3 years, and I thought it would be nice to have a listing of the parts and my experience with them. Take it or leave it, this is just a happy customer who’s been enthusiastic about their car for quite some time.
I’ll try to go in chronological order since that’s how my expense history is also listed.
10/15/08 - 48k - H-Sport Rear Sway Bar for B6/B7
[INDENT]This was my first real performance mod, and coming from a RWD car, the understeer in this platform is blatantly obvious. I was a bit skeptical how much it would make a difference, but to my surprise, the car responded quite well. I set mine on the “aggressive” setting from the beginning and have never looked back, nor have I broken any of the sway end links (knock on wood).
You still have a bit of understeer, but it does dial it back a good bit, and that was my goal. If understeer is a issue to you, it’s a great mod, and only do the rear, as adding the front will dial the understeer back in (but also bring a lot of composure and response to the front end). Doing the full set (I’m told) is a significant improvement, and great for track orientation, but swapping out the rear only is how you get it more tail happy.
http://jhmotorsports.com/shop/catalog/images/H-sport_Sway_bar_kit.jpg
[/INDENT]
[INDENT]The downshift. . . Blipping the throttle in this car is not easy with stock pedals regardless of what say. It’s a common issue, and replacing the pedals really do help this. The reason it helps is b/c most all of the aftermarket pedals raise the gas pedal height once installed. Not significantly, but it’s enough to make a difference. This really made a difference in how I could drive the car as I didn’t have to contort my leg to blip the throttle while braking. And to me, it also added a subtle look that was a nice touch for those who catch a glimpse.
http://www.jhmotorsports.com/products/pictures/pedals/JHM_SRP_Pedals_Installed.jpg
[/INDENT]
12/15/08 - 51k - H&R C.O. (purchased used through classifieds)
[INDENT]I did this mainly for the appearance of lowering the car. I wanted to increase handling some, but track purpose wasn’t a main concern. After installing these, I’ve been very happy. They’re a good set for the money, and allow for ride height adjustment. Changing the front height is pretty easy on most any c.o. option, but the rears are a pain as the subframe has to be lowered (and does on most all c.o. option I believe as it is not a “true” c.o. in the rear). If I had to do it again, I would. They were a great value, gave me all I wanted and more, and seems to be a pretty quality part. They are stiff (and can not be adjusted as some others can), but I personally like the ride and performance of the kit. (alignment is a must after any suspension work as well)
http://3werks.com/Audi/images/HR%20coilovers.jpg
[/INDENT]
12/15/2008 - 51k - JHM Short Shifter (extra short throw with stiff springs installed)
[INDENT]What can I say that others can’t? This really is (in my opinion) the absolute best shifter made for our cars. Once you have it in hand, and see the design, craftsmanship, and quality of parts being used, it clear. I’ve had this for several years now and I still love it. I didn’t install it (and I know the install is tricky for first time users), so I can’t shed much light on that. But I can tell you that as one of my early mods to the car, it’s still one of my favorite. It’s just so much better than almost any other shifter that I’ve driven with. I recently did the “trio pkg” and my performance shop was in amazement at how it felt when they pulled the car around. He said he’d never felt a shifter like that.
http://jhmotorsports.com/shop/catalog/images/b6_6speed_shifter_shaft.jpg
[/INDENT]
[INDENT]I know this isn’t performance parts, but I just want to emphasis the importance of doing preventative maintenance on this car. This is a high performance german sedan, it should be treated as such. Just b/c Audi says 15k, or 50k for this or that, it is of my feeling it is well worth my time and money to replace parts much more frequently then that. Arguments can fly around this, but I have the peace of mind knowing I’m keeping the car in the best shape that I can, and hopefully preventing extra wear on other parts and reducing malfunctions. I plan on keeping the car probably to 150k, and b/c of that, I want it to be in top shape.
http://jhmotorsports.com/shop/catalog/images/B6-B7_S4_Fuel_Filter_OEM.jpg
[/INDENT]
Winter 2008 - 52k - Front Window Regulator
[INDENT]Yeep, they go out for sure. It’ll start off with the window not always going all the way up with the “auto” feature. Or possibly by making a grinding/crunching noise (It’s usually where the partially frayed metal wire is cutting/grinding into the plastic pulley assembly). After you do it once or twice, replacement is pretty easy, but the first time is a bit daunting if you’ve never done work like that before. One thing to watch out for (if you have tinted windows) is to be very careful with moving the window during the install of the regulator, as well as re-installing it in the car. The second regulator I replaced, I scratched the tint on my window b/c I wasn’t paying enough attention.
http://jhmotorsports.com/shop/catalog/images/B6-B7_S4_window_regulator_front_left_8E0837461C.jpg
[/INDENT]
7/1/09 - 56k - Lubro Moly 5W40
[INDENT]Now that the car wasn’t being serviced by the dealer anymore, and I had begun to be active on the forums, I decided it would be the right decision to switch to a higher quality oil and increase the service intervals. I’ve never had chain rattle (knock on wood) and have been very happy with the product. The price is expensive, but all quality oils are. I feel that you get what you pay for (most of the time at least), and when it came to oil, it’s well worth my oil. I also started using a Pella Oil Extractor at the time. It works well, but b/c I’m paranoid, I would still change my oil the old fashion way every third change. But if you measure the quantity the extractor pulled out, it almost exactly matched what should be in, and 9.5 qts always put me right back to med part of the fill line. Once I removed the drain plug and had little to nothing seep out. But now that I have access to a lift, it’s easier to do it the old fashion way, but with parking lots at school the pella was ideal.
http://jhmotorsports.com/shop/catalog/images/B6B7_S4_Oil_Change_Kit_w_drain_plug_ring.jpg
[/INDENT]
1/4/10 - 60k - Apikol Rear Diff Mount
[INDENT]As others have said, this really does clean up some of the drivetrain slop, and is especially noticeable between the 1-2 shift. Install is pretty easy with a set of ramps, jack stands, and jack. But most of all, it works! Nothing game changing here, but any extra slop or vibration between transitions (of power, shifts, bumps etc) means more wear on parts usually. And this just tightens everything up. If ya got it in the group discount last week, then I’m sure you’ll soon see what I’m referring to. Not the first mod I recommend doing, but it’s great to throw on your list and knock out when you have some other maintenance issues to look at. Also good to change your rear diff fluid while you’re back there. Also pretty straightforward and nice peace of mind (and this is when I did mine).
1/4/10 - 60k - JHM 4:1 Center Diff Upgrade
[INDENT]First off, for clarification, ALL of the B6 & only the manual B7’s that are 2005.5 only, have the 50:50 power split (all the automatics cars have this 50:50 split). Since I’m a 2005.5 I fall into this category. And since I mentioned, I miss the tail happy nature of RWD cars, this had been on my list for a while. This is THE EXACT SAME as the Stasis 4:1 diff, but $200 bucks cheaper. And I had seen a writeup on another platform about being able to buy the different washers and change out yourself, but that’s a can of worms I didn’t want to open. The swap out was pretty straight forward, and honestly, my biggest challenge was removing the driveshaft from the rear of the center diff (kind of a vacuum effect with the grease and the flexible joint makes it tough to get a good pull), that and the differential bolt at 12 o’clock. After it’s out, it’s just a matter of swapping the cores, bolting it up, and refilling the oil. I was also pleasantly surprised with the response of the car here. Again, nothing game changing, but for a b^ or a 2005.5 B7 to do the rear sway, center diff, and rear diff mount, I think they’d really be surprised at how the rear end is able to move around a bit more and how it pulls some of the understeer out of the car. (also a good time to do a fluid drain and swap, not all the oil will drain out when just changing diff)
http://jhmotorsports.com/shop/catalog/images/JHM_4_to_1_Center_Diff.jpg
[/INDENT]
1/4/10 - 60k - Hawk HPS Street Pads, F&R
[INDENT]My pads were due for a change so I thought this would be a good performance route to go. This was my first time to ever touch a brakes and honestly, it wasn’t that bad. Having the right tools is key (i.e. the rear calipers need to have a brake tool that can spin them in the proper direction for each caliper to push the caliper back for clearance of the new pads), and patience with any stubborn bolts is also important. Since I was only doing pads here, the brake fluid did not need to be bled or refilled. Doing only pads and rotors is a pretty straight forward job and the average DIY-er shouldn’t hesitate to tackle this.
However, the one thing to make sure you do (as mentioned in another thread) is to BED THE PADS IN PROPERLY and make it the first thing you do. Plan your schedule so you can make this happen. I finished up around midnight and it made it very easy to go bed them in properly. Also, waiting a day or after the first bedding procedure and doing it again is a good idea. Often, some rotors or pads have a small first coating to protect them and to react to the bed in procedure. You need to remove these coatings (if they have it) as the first thing you do after the installation. And make sure never to come to a full stop when bedding them or to use the parking brake when done. (i.e. in gear on flat road and let cool for 15 min after done. Your pads, or manufacture should have specific info on this) Also, don’t think more is better when it comes to the speed recommend for breaking the pads in, follow the directions, and you’ll be fine.
http://jhmotorsports.com/shop/catalog/images/Hawk_HPS_pads.jpg
[/INDENT]
1/4/10 - 60k - Adams Slotted & Dimpled Rotors F&R
[INDENT]I did these at the same time as my Hawk Pads. It’s tough to say how much bite the pads gave vs the grooving in the new rotors. Mostly was the pads for sure, but slotted rotors will certainly eat at pads quicker. These rotors are a good value for a look past oem, but their main purpose is appearance. I did have some increased noise, a slight hissing sound, when braking, and I believe that is due to the dimples or slots, it’s common and didn’t bother me. That said, I was happy with them for the time period that I had them, and they served me well. Install is pretty easy once you’re doing pads. One of my OEM rotors was frozen on, and it took a couple knocks with some wood & a hammer, but otherwise all went smooth.
http://i33.photobucket.com/albums/d97/killahcortez/black_zinc_lg.jpg
[/INDENT]
