Hi I didn’t want to just past the huge log but it doesn’t look like I can attach a text file ?
Here’s the log extract where the faults are
Monday,22,June,2020,16:26:53:64284
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 57890km-35971mi Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 20 22 36 42 44 46 47
52 53 56 5C 5F 6C
VIN: Mileage: 57890km-35971miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
04-Steering Angle – Status: OK 0000
06-Seat Mem. Pass – Status: OK 0000
13-Auto Dist. Reg – Status: Malfunction 0010
15-Airbags – Status: OK 0000
1B-Active Steering – Status: OK 0000
20-High Beam Assist. – Status: OK 0000
22-AWD – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
56-Radio – Status: OK 0000
5C-Lane Maintain. – Status: OK 0000
5F-Information Electr. – Status: OK 0000
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l JHM93 / H04 0003
Revision: NAH04—
Coding: 1A25003225C6000A3000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E73EE15A18CA97639-806A
1 Fault Found:
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 57824 km
Date: 2020.06.20
Time: 11:41:38
Engine speed: 1327.50 /min
Normed load value: 38.8 %
Vehicle speed: 27 km/h
Coolant temperature: 99 °C
Intake air temperature: 45 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.206 V
Unlearning counter according OBD: 37
Engine status-Bits 0-7: 3
Engine oil temperature: 103.6 °C
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8T0 927 156 H HW: 0B5 927 156 J
Component: 0B5 42 FSINAR H01 0005
Revision: --H01—
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021.rod
VCID: 428B9AE5D574CD965D-8016
1 Fault Found:
18053 - Shift Fork 3
P284B 00 [096] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 57824 km
Date: 2020.06.20
Time: 11:41:38
Engine speed: 1158 /min
Transmission input speed: 1158 /min
Transmission output speed: 221 /min
Engine torque: 228 Nm
Transmission fluid temperature: 77 °C
Accelerator position: 24.0 %
Clutch status: Kupplung 2 kann Moment übertragen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 2C6D0A
Shop #: WSC 06324 000 00000
VCID: 458181F9CC5AFAAE78-8010
1 Fault Found:
01315 - Transmission Control Module
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 227
Mileage: 57824 km
Time Indication: 0
Date: 2020.06.20
Time: 11:41:38
Freeze Frame:
Hex Value: 0x1B00
Hex Value: 0x4006
Hex Value: 0x120E
Hex Value: 0x23B4
Hex Value: 0x0000
