Can someone that has the JHM supercharger please post a picture of your PCV system. I need to make sure mine is in the right direction.
Which part are you concerned with? The big valve that goes by the electrical connectors are the additional piece at the back of the intake manifold?
I want to make sure I didn’t install anything backwards or if i was supposed to leave the pancake disc out. The PCV install is not included in the instructions.
I am pretty sure that the big valve is in the instructions. That is connected to the silicone SC hoses and the long L shaped silicone line that is attached to the big plastic T fitting. There is a small valve and hose that goes between the intake manifold and the PCV valve.
im not entirely certain which piece you mean. do these pics help? I know the instructions can be a bit out of order and skip over a couple things that im sure the guys just see as a “no brainer” I tried to include most of those in my install thread.
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150725_234908_zpsr70fuynj.jpg
http://i1270.photobucket.com/albums/jj615/Garrett_Hargreaves/Mobile%20Uploads/20150725_234921_zpsor9ex3vf.jpg
let me know if u want to see anything else specifically. im under the hood putting some more parts in so I can snap a pic of anything u want to see.
Perry, post a pic of what is concerning you and I will let you know!
Thanks for the concern guys. I hope I have found my long lasting issue with the help of JimS4 old thread. Probably a bad new MAF replacement from the start.
