Looking for some clarification on exactly how the SAI delete function works on the JHM tune. I currently have the sai blower motor removed, the solenoid on the front of the engine by the intake manifold removed and all associated plumbing removed and capped.
I had the JHM tune with SAI delete option loaded last night but still get the SAI code for sysmtem open circuit. Am I right in assuming that I am getting this fault because of that little grey solenoid being unplugged on the front of the engine? Or should the software completwly and entirely remove the SAI sysmtem entirely?
I sent the car up with a good friend to have the flash done as I wasnt able to make it up to the show where the JHM rep would be.
When I pick it up i’ll plug in that piece to see if it clears but figured I would check here first in case the software needs to be reflashed since my car and the Rep are at the same place, otherwise it is a 4 hour drive i woild rather not make lol.
