Will be calling Chicago Performance Tuning and asking Al to get signed up. Since I already paid for Revo stg1 2 years ago - should I explore stage 2 add on or is Revo stg 2 useless??
garbage. usually for catless setups. they tune out the rear o2s because theyre not competent enough to change the flow parameters therefore not retaining diagnostic capability or long term fueltrims. i would wager they throw more timing at it as well. no bueno.
YThat’s a nice succinct assessment. I agree with it. I wouldn’t gamble on Revo stuff although their b8tune kicks ass. They’re also the only b8 tuner to have the blood of a few engine failures on their hands though…So that doesn’t bode well. Parameters on some of the b8 files I’ve seen were borderline shocking. I. E. They basically ran the same timing on their 93 file as Apr did on their race gas file… And we never saw a Revo tuned b8 Car pulling timing on logs despite this. So it looks like they were desensitizing the hell out of knock sensing thresholds.
Since stasis took over apparently they have dialed the tune back a bit on that platform.
Bottom line is Revo appears to be gambling and I don’t think that is exactly ideal.
Personally I can’t believe that anyone considers anything other than jhm for the 4.2 na cars. It seems insane.
Yeah I guess that was annoying but that’s for the rs4 only… The s4 guys were chip tuned business as usual.
I still think that is nuts though. They were offline for the rs4 for what… 6-9 months?
If someone needed a tune so bad during that time that they bought giac or apr I would wonder about that decision. That tells me they’re only keeping the car a short time.
If you decide to go to a great restaurant for your favourite food, and getting a table takes an extra 30 minutes because they’re on a wait, and then dinner takes an extra twenty minutes vs normal service because they’re so busy, how often do you leave the table and go next door to the burger joint just because you’re hungry?
Haha, not sure why they came across that way but hey, it happens. Especially when you are good at what you do people tend to get a bit of an attitude. I’ve had CPT do work on my car and they are top notch, but very expensive.
B6joe - where is Mobil 1 shop ?? I agree CPT is pricey.
When I got the car in 2009 - I tried to get an APR tune but they could not flash it as I did not have a Bosch ECU but rather Simpkin. So the only dealer around me for tuning was Athons motors - Revo.
They’re in glenview right off Leigh. I think they’re already a dealer for Uni or something like that. Not sure how those contracts work but I’ve never seen a shop that’s a dealer for multiple tuning companies. Although JHM is very small
Not only is CPT very pricey, but there’s a good chance, in my opinion at least, that Al won’t want to make that partnership with JHM. I had him install my JHM clutch/flywheel and he didn’t exactly express the same excitement about JHM’s aftermarket parts as I did. He was unimpressed with the flywheel because it was aluminum and with the clutch pressure plate because it was sprung. I was at least able to convince Al that their customer service was top notch as they were able to give me credit for my damaged clutch flywheel kit because the first installer screwed up the installation.
I didn’t want to say anything previously but my impression is that they (CPT) aren’t gigantic fans. Not against, but certainly nowhere as enthusiastic as the group here.
Regardless, JHM told me specifically that they were trying to get CPT on board. It would really suck if JHM doesn’t partner with someone in Chicago soon. It’s a big market and I really want to get the tune this spring. Not sure i am interested in self-flashing.
I could see that. When I called to get a quote to recharge my ac after I did all the cleaning on the front of the motor and mounts, etc, I simply asked if they could recharge it for me because I had the front clip off. And his answer was, “now why would you even do that?, you probably need a new compressor now.” wtf?
But I have to give them credit for their top notch quality of work, but that owner is just plain ignorant.
Just don’t forget your own successful launch technique. I found I got better 60’ times without LA last time we went to the strip (when the printer was broken lol)
Launch Assist works incredibly well in a particular set of circumstances, and very well in just about all circumstances.
It won’t adapt though, so you have to keep that in mind. It’s not the Ferrari system that learns based on GPS and previous launches.
It’s basically a safety net…a fail safe…to allow anyone to launch the car effectively. If you are at the strip and it’s working well, go balls deep and keep using it. Bangoman if I recall correctly, two dragstrip visits ago you had your best ever 1.8 60’ times by using Launch Assist.
