Hi all, I am excited to report that I just got JHM tuned yesterday. The process went smoothly and only took about 45 mins.
Although I still have the stock dp and catback, I definitely feel a noticeable increase in low-end torque. Unlike the stock tune, the car now pulls hard all the way to higher rpms too.
I also did some maintenance stuff on the car as well. ATF was changed, and the shifts now are very smooth.All of the plugs were changed as well as fuel filter. I also requested a compression test for the car. The results are in the picture below. My mechanic said 140 is little on the low side. Just wondering if it is something that I should be worried about. If this makes any difference, the test was done when the car has been sitting in 3C or around 40F for maybe 1.5 hours then in the warm shop for another 45 mins. And the car also had fresh oil taht was changed yesterday with liqui moly 5w40. We also found out the valve cover gaskets are leaking again, after the dealer who sold me the car supposedly have replaced just before selling me the car 2 years ago. It is not leaking bad, but pretty annoying.
A big thanks goes out to Shift Autosport in Burnaby, BC for setting me up with the tune, as well as The Speed Syndicate for the work done on my car.
