All the tune knock discussion had me looking into alternative ways of analyzing how tuners were tweaking the knock response loop and I came across VAGCOM blocks that log actual knock sensor voltage vs. timing pull.
http://www.ross-tech.com/vag-com/m_blocks/020-029.html
Do you know if anyone has tried to log both the voltage and the timing pull so see how they are correlated for a given vendors tune.
Since “desensitizing” the knock sensors in application is reprogramming how the ECU responds to a given voltage value it would be really interesting to see at what voltages trigger how many degrees of pull under given conditions and compare that across OEM, GIAC, APR, REVO.
I thought that might be interesting, but I obviously have very little experience in this area so putting it out there to see if I am totally off base or if you guys had any thoughts or insights.
