https://www.youtube.com/watch?v=p6ze68ccUJ8
It got worse. I have a video of the play now but I haven’t uploaded it to youtube yet. Soon.
To fix the problem, I scooped up basically the entire front suspension off some guy online for $80 both sides. My mechanic swapped on both spindles and OEM upper control arms. Quite frankly, the 034 units were shit and have a shit design. My issues with them were that my old mechanic(also shit, notice the trend?) didn’t tighten the nut enough on the 034 units so the nut ended up backing off towards the ball joint side. The nut, through the travel of the suspension, contacted the spindle and at some point stretched the pinch bolt and wedged it in there. BOTH forward and rearward control arm pins ended up not having the proper torque on them and BOTH were not seated properly. Sure, this is my problem. However, what is even more interesting is that on the other spindle with two properly seated pins and secured bolts has similar smearing/contact between the spindle and the securing nut on the control arms. Basically, the smaller you adjust the control arms, the more contact there will be and the more likely something similar to this situation could happen to you.
Outside of this, the control arms were noisy and wore out in 2 winters. I wouldn’t recommend these for anyone in a snow state. They’d probably be fine for california :
but not everybody is graced with good roads and no precipitation.
