Symptoms that led to scan: ESP/traction control light & sometimes poor accel from stop.
Pertinent codes from VCDS, which when I clear they come back:
Address 01: Engine (BXA) Labels:. User\07L-910-552-BSM1.lbl
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH02— Serial number:
Coding: 01050009190F0160
Shop #: WSC 03323 444 11564
VCID: 2310E78D97D337234E0-8076
6 Faults Found:
001433 - Thermostat for Mapped Engine Cooling (F265)
P0599 - 001 - Short to Ground
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:39:16
Freeze Frame:
RPM: 1550 /min
Load: 41.2 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 42.0°C
Absolute Pres.: 970.0 mbar
Voltage: 11.684 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
Freeze Frame:
RPM: 702 /min
Load: 32.9 %
Speed: 1.0 km/h
Temperature: 73.0°C
Temperature: 36.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
Freeze Frame:
RPM: 702 /min
Load: 32.9 %
Speed: 1.0 km/h
Temperature: 73.0°C
Temperature: 36.0°C
Voltage: 14.351 V
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242532 km
Time Indication: 0
Date: 2021.02.22
Time: 16:49:02
Freeze Frame:
RPM: 979 /min
Load: 16.1 %
Speed: 33.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.351 V
009525 - Ignition Switch; Run/Start Position Circuit
P2535 - 001 - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242533 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 92.0°C
Temperature: 27.0°C
Voltage: 12.065 V
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242533 km
Time Indication: 0
Date: 2021.02.22
Time: 16:57:31
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 92.0°C
Temperature: 26.0°C
Voltage: 11.811 V
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Coding: 0020920
Shop #: WSC 02335 785 00200
VCID: 313C1DC5DD2F95B3CCC-8064
1 Fault Found:
00526 - Brake Light Switch (F)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 97
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0004
Hex Value: 0xB0B1
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600975421
Coding: 0000007
VCID: 2412E49192DD301B37A-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H46 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 97
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:56
Address 11: Engine II Labels:. User\07L-910-552-BSM2.lbl
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
Freeze Frame:
RPM: 708 /min
Load: 32.9 %
Speed: 1.0 km/h
Temperature: 73.0°C
Temperature: 36.0°C
Voltage: 14.351 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
Freeze Frame:
RPM: 708 /min
Load: 32.9 %
Speed: 1.0 km/h
Temperature: 73.0°C
Temperature: 36.0°C
Voltage: 14.351 V
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01093179240000
Coding: 4618269
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 57
Mileage: 94350 km
Time Indication: 0
Date: 2014.01.30
Time: 18:28:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 97
Mileage: 242530 km
Time Indication: 0
Date: 2021.02.22
Time: 16:40:45
