Lean Codes After Intake Replacement
I figured I would start a new thread that is specific to the current issue that I am having.
I recently replace my intake manifold with a new one from JHM, along with installing the JHM intake spacers.
I had codes for the intake flaps being stuck open but fixed that issue by removing the last metal bracket on the front drivers side of the engine.
I now have new codes: P1081, P1085, P2189, P2187. These are all codes pointing to a lean mixture so I most likely have leaks or a leak somewhere.
I will be replacing my air distribution housing, as mine has a broken bolt fitting on one of the throttle body flanges and is distorted. But I don’t think that is the leak.
I will also be replacing my PCV/oil separator as these can cause this problem also. I have the same codes as referenced in this post: http://audirevolution.net/forum/index.php?topic=3967.0 The problem he had was a ripped diaphram in the PCV. I am hoping this is my problem but I am not sure.
I will also replace my PCV/valve cover pipe as on my car, one end is wrapped in electrical tape and and could be the issue. Its a good idea to replace it anyway.
Another thing I noticed yesterday is that I can hear a high pitched whistling sound coming from the air distribution housing coming from somewhere where it connects to the intake. I am thinking this is not normal? It sounds like it is coming from the passenger side but it is hard to pinpoint exactly where. Maybe what I am hearing is the PCV leaking? Anyone have this problem before?
Another thing I will also do is change out the valve cover gaskets. When I changed my sparkplugs, nearly every hole had a good bit of oil in them and I have read that leaking valve cover gaskets can cause lean codes. I also think it is a good idea as regular maintenance.
As for trying to diagnose the vacuum leak, I tried propane but could not hear any change in idle. But a change in idle would only happen if the leak in in the intake track? I assume if it is the PCV, this would not make a change in the idle as it is not in the intake path and so the propane would not make it to the cylinders? Am I correct in thinking that?
I think I will try starting fluid instead. Maybe I wasn’t using the propane correctly.
I will update this thread as I discover more or fix my problem. Thanks.
