Lean Codes
While taking a few hundred mile drive about a week ago I had the following codes pop-up and illuminate the MIL
P0174 - Powertrain - System too Lean (Bank 2)
P1075 - Powertrain - O2 sensor too lean (Bank 3)
P1077 - Powertrain - O2 sensor too lean (Bank 4)
I could not detect any drive-ability issues and the car revs just fine. I cleared the codes and they were gone for about 2 days of light driving but have now come back.
I noticed another thread with the same O2 codes but also a Fuel Pressure code which seemed to indicate the HPFP, however that issue also caused a failure to rev properly which my car is not having.
I believe these codes are all pointing to the driver side bank of cylinders. I plan to check for any split hoses or air leaks tomorrow but I just changed the air filters about 2k miles ago and both sides looked really good. Could this also be a failing HPFP? I do have a full VAG-COM cable so I can take logs but I’m not sure what I should check.
Any help would be appreciated, thank you!
