Light Smoke in Engine Bay
[Continuation of topic: “C6 S6 Misfire”. See topic for contextual and potentially relevant information associated with the below]
It turns out that the smoke and smell coming from the driver side engine bay was a leak in the oil pan, according to Audi. At high velocity, some of the oil would come in contact with a component that generally operates at a high temperature, causing it to vaporize and smoke to emerge. At least, they’re fixing that now, and it seemed to make sense to them.
I have yet to pick up the car, so I’ll find out on the BRAKE indicator light pretty soon. I haven’t had a misfire in quite some time, so after I get the car back, I’ll have to get up to my usual antics and see if the issue resurfaces. I generally keep the gas tank at least half full (seem to have fewer issues when I do), but I’ve ran it lower recently to put Techron in and haven’t had any of the issues with rough starts or anything that I’d had before, but I’m not convinced the problem is solved completely yet.
Will definitely keep you guys posted, thanks for your time so far.
Was playing around with an SRT8 on the highway, and I swear I could smell the smell that was associated when the car would produce that smoke I talked about earlier. I could be crazy, but I also notice that my car pulls to the right slightly when breaking. The smoke could potentially be coming from the brake on the left side, but I can’t tell for sure. The other day, just that rotor was covered in rust–it looked like water had dripped all over it, and where the water contacted the rotor, it rusted. I looked a day later and the rust was gone.
[Update]
I’ve noticed the car having a bit of a rough idle, and I think it’s pretty much always had that issue. It may be related to the ZF Lurch, I’m not sure, but the issue in that topic is definitely what I’m experiencing as well. Someone had mentioned the potentiality of bushings or control arms in the front causing an issue with alignment and tire wear, I wonder if that could be that? If the bushings need to be replaced, would that make the car idle rougher possibly? Also, the car definitely has a rougher start as my gas tank gets lower, as well as in very cold weather (well, this was true last winter, can’t tell if this is still true yet) and sometimes on certain inclines. I’m guessing fuel pump, filter, or both? Not sure.
Also, couple of things that I think might be connected I guess, but have no idea:
  1. when turning the car sharply, the car rumbles depending on how sharp of a turn you’re making. I’ve been told (at least, this is how I undestood it) that this is just an AWD issue caused by all the wheels not being able to turn fast enough at certain angles but are still rotating, so the ratio of the car’s velocity and the steering angle is too high and cannot be accounted for by traction control or any other feature. Could this be false and could something be rubbing on the driver side that is causing smoke at high speeds and high steering angles at high speed?
  2. I haven’t had to do it in several months, but reversing (either up or down, I can’t remember, sorry) a hill would cause a metal-to-metal sound that seemed to be produced by steering at certain angles. Control arms maybe?
  3. Sometimes, on heavy acceleration, the car seems to stop accelerating at a fixed RPM (usually 6000) at random times. I’ve primarily noticed it in 2nd gear after accelerating to around the redline in first and then approaching it in 2nd from either a stop or a slow rolling start.
The other day, the EPC light came on for a while. I believe I was below half a tank of gas, but I didn’t catch what triggered it. I don’t remember doing anything too crazy on the RPM-scale but could be wrong. If I did mess around, the car would have been about 75% on the way to operating temperature. The engine does seem a little rough when it’s not at operating temperature, but I’m guessing that’s normal for an engine this size (the biggest I’ve ever really experienced, so I don’t know for sure due to lack of reference)
No misfires for quite some time now.
