Darn! Ron / Josh, may I email you both my logs? The file is too big to attach!
here is the scoop though:
Here is the full logs, I added in the “gear” under the marker field as well just to ease my viewing. The log started around 10mph, went WOT and the car downshifted into 1st gear, and of course either spun through 1st gear.
1st gear observations, lots of boost bleed, surprised that my actual ignition timing went to 27.75 degrees at redline (or is the actual field the requested timing? zero corrections on cylinder 1 aside from when I hit a series of bumps). IAT’s dropped from 40.5C to 39.75C by the end of the run when it upshifted at 7,199rpm.
2nd gear observations, lots of boost bleed (up to 20.99% by 5,050rpm) given that I am sure I was still spinning the wheels (If you ever got WOT in the day through 1st and 2nd gears and look in the rear view mirror, you’ll see tire marks on the ground from the start of where you went WOT in the lower gears). The boost bleed lowers to 4.02% at 6,592rpm, and the ECU/TCU decides to shortshifts at 6,771rpm. Ignition timing tops again at 27.75 degrees and IAT’s goes up to 51.75C.
The upshift into 3rd gear lands me at 4,650rpm (due to the shortshifting from 2nd gear) with boost bleeding starting at 6.28% rising to 11.46% by 5,080rpm. After 5,205rpm the car gains some composure and bleeding drops from 9.1% to 0% by 5,676rpm and starts to bleed ever so slightly up to 5.72% from 6,455rpm - upshift at 7000rpm (confirmed by seat of the pants sensation as the car pulled like a monster starting at 5,205rpm through the upshift at 7,000rpm would allow for some bleeding for safety reasons). Ignition timing targets are lower in this gear at 24.75degrees @ 7,000rpm. Intake temps rose to 66.75C
The upshift into 4th gear caught me by surprise, as the car felt very strong on my butt dyno in this gear (like it had full power, and the logs confirmed it). Zero boost bleed in this gear where I shut it down at 5,635rpm due to road limitations. IAT’s rose to 71.25C, and ignition timing rose to 19.125 degrees at 5,676rpm, about 2 degrees lower at a similar RPM in 3rd gear, which would tell me that the ECU selected a lower table due to IAT’s rising. I would have loved to see 4th gear through redline on this log to confirm my previous butt dyno feelings where it was very strong through redline on track day.
I’ll do some 3rd gear 3000rpm into 4th gear redline logs soon to minimize the effects of wheelspin in 1st and 2nd gears. However, I will tell you that despite the timing on this log confirming its relatively healthy, I’m wondering if I’m overshooting GIAC’s requested boost targets in the mid-range which is causing the boost bleed up to 5,000rpm or if I’m starving for fuel due to the E85/93 mix causing the boost bleed? If its fueling issues, wouldn’t I have ignition timing issues and corrections as well?
^^Should I log just lambda values to see? Or should I also log fuel-trims? Let me know, I will get it to you guys.
