also funny
[quote=ARIN@APR][b]Now to explain what’s going on here. Basically the ECU is told it should see a set amount of boost pressure. When the ECU gets NEAR that level, it will react and dump boost, so since we want to take advantage of all the boost pressure the charger can product, because we’ve tested and found it’s safe and that the fueling system can even keep up at sea level in very very cold environments, we told the ecu to bump up the boost set point in different weather conditions. What happens is the bypass valve says shut and more pressure is produced.
With version 1 software we did not tell the ECU to bump up the request enough in cold weather. Because of this the bypass valve opened a little and lost pressure. It turned out to be more pressure than we would have liked, which did result in less power being made, but it was still safe. [/b]
a.k.a. we saw that REVO smoked us by asking for unattainable levels of boost, which meant the bleed would be ZERO full time, so we did the same. We’re sorry we scoffed at this in REVO’s thread. We know we look silly.
lol
