M5 is gone, picked up a new toy.. UrS4 content..
So recently “Da Fridge” went up for sale over on Quattroworld and it was a car I really didn’t want to pass up. Ending up selling the M5 fairly quickly and was able to pick up the S4…
Some details on the car…
Engine
-VEMS Engine Management
-Saenz Forged Connecting Rods
-ARP Main/Rod/Head studs, MLS Head Gasket
-HTA3582, .82 A/R, TiAL stainless steel v-banded turbine housing.
-Iroz Motorsport Header - Equal length, tig welded back-purged 304 stainless steel, per-cylinder EGT bungs, v-banded for TiAL turbine housing, wastegate, and downpipe. Coated with Swaintech White Lightning thermal barrier coating.
-TiAL MVR44 Water-cooled, billet aluminum/stainless wastegate
-FIC 2150cc EV14 injectors
-Apikol Intake Manifold
-3B valve cover, powdercoated
-Gen 1 Apikol FMIC (24"x10"x3.5")
-Tial 50mm BOV
-034 High Output Ignition Coils
-Custom catch can setup
-Setrab 25row Oil Cooler
-Vanjen clamps/Samco Boost Hoses
Fuel
-IE dual 044 surge tank
-EFI-X billet -8AN fuel rail
-044 pump feeding surge
-Weldon adjustable FPR
Exhaust
-Iroz Motorsport 3" v-banded downpipe
-3" Stromung Turbo-back Exhaust
-3" Electric exhaust cutout w/ side dump
Head
-7A Cams
-Ported & Polished
-.5mm Oversize Intake valves
-.5mm Oversize Exhaust valves
-High rate valve springs
-Titanium retainers
-Lightweight lifters
Drivetrain
-6-speed EDU transmission
-10.5lb JB Racing Aluminum FlyWheel
-SouthBend Stage 4 clutch
-Apikol Short Shifter
-V8 Torsen Rear Differential
-Apikol Rear Diff mount
-Poly snub mount/crossmember mounts/etc
-Solid front subframe bushings
-Poly engine mounts
Suspension
-Custom Eibach coilovers
-Revalved Bilstein sports (+10% compression, +30% rebound)
-2Bennett Camber Plates
-Apikol/Hap big rear sway bar
-Apikol Sway Mounts
Brakes
-993TT front brakes
-Boxster S rear brakes
-Custom Hydraulic Handbrake
-Stainless brake lines
Lighting
-Euro spec headlights w/ relayed 55W HIDs (4300k) & Headlight adjuster motors
-Hella Clear Corners
-Euro A6 center taillights / Euro corner lights
Interior
-OE Carbon Fiber trim
-VEMS LCD screen - displays rpm, labmda, coolant temp, EGT, MAP, IAT, and throttle position in real time
-Custom hardwired V1 w/ concealed display in instrument cluster, and remote audio controller in center console
-Forge billet shift knob
-Sullivan Racing billet pedals
Wheels/Tires
-SSR Comp 18x8.5 et35 wheels
-HTR ZIII tires 255/35/18
http://img.tapatalk.com/d/14/05/08/uqema9ym.jpg
http://img.tapatalk.com/d/14/05/08/yry9abe4.jpg
http://img.tapatalk.com/d/14/05/08/6y3evyqy.jpg
