Methanol Injection Install
Two things one should know about an Aquamist install. 8-12 hours and talk to Jeff before you order. He told me “usually” people tell him what kind of a car it is going in? My tech had to rewire the control box for my Audi, three hours. Jeff’s excuse was I didn’t tell him. Yet no where in the web page does it make a request for such information. Regardless, the bar graph starts illuminates, at least in my car, at 4000 RPM and quickly goes all the way across to almost full. Complex system but good quality gear. Tank has two joined compartments. The one with the pump is full of little ping pong sized balls with holes in them to prevent sloshing allowing easier pick up. The vertical bar in the tank is an illuminated site gauge and the box has a small fan in it. Allegedly Aquamist is the only system on the market one may run all methanol through. Also, if one gets really enthusiastic one may run an injector to each inlet since it’s, allegedly, the only one you can do so with?
http://www.howertonengineering.net/aquamist-hfs-4-injection-system/
http://i.imgur.com/alee8Zb.jpg
http://i.imgur.com/Z2Mj3b9.jpg
