So I had to pull the engine due to a massive failure. Passenger side exhaust cam spun and bent the valves on that side. I pulled the engine and had the head rebuilt. I just got the engine back in but now I have a small miss (not a dead miss) when i checked the faults no faults but i checked messureing value blocks and you can see the miss on clynder 7 & 8
I had the injectors cleaned before re installing the engine
I changed all the plugs
When i found the miss ive:
Swaped the coils to see if the miss travels
I checked the spark plug gap
I checked the compression on 6: 165 7:165 8:165
Not sure where to go from here
thanks for the help!
