Motor Issues
Hey guy, Im back. Missed the comfort of my S4 for daily driving so I picked up one with a bad motor, avant, automatic. I have the parts for a 6 speed swap and will probably do a 2.7t swap into it. I know flame on. I posted this over on AZ yesterday but figured there are some more knowledage people here.
Anyway the real reason I am here. Owners discription of what happened was that he got off an exit got onto it and the car started shaking violently and running like crap and then wouldn’t restart. Sounded like a snapped guide to me but I figured he had it properly diagnosed an I know these motors have issues with timing (this one being an 04 with 100K on it, it was right at the time we see issues like this pop up). When I first got the car I did a quick scan for the hell of it. Got the following codes. I tried turning the car over and all I got was grinding sound from the starter and proceeded to pull the motor.
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 C HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Coding: 0007771
Shop #: WSC 63251 000 00000
VCID: 254BCA93EF078E3073D
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16692 - Cylinder 8
P0308 - 001 - Misfire Detected
16705 - Engine Speed Sensor (G28)
P0321 - 008 - Implausible Signal
Readiness: 0000 0000
Well I finally got around to separating the motor and trans tonight. Starter looked like it might be shot. All the spark plugs looked fine. I was able to spin the crank up front by hand(with some difficulty) to remove the trans and torque converter bolts. Once that was off I was able to get a breaker bar on the back of the motor and turn it over real easily with out any skipping or jerking I have experienced from the previous motors I have had with timing guide failure. What was strange is when I first started turning the motor over the drivers side “belched” up about a cup of fuel? maybe water? out of the exhaust manifold. It smelt like fuel, but seems like a lot of fuel to be sitting in the cylinders on only one side.
Any chance this motor is still good? I guess I am just at a lose of why a somewhat significant amount of fluid came out the drivers manifold. Seems like the motor had compression. I guess I am looking for advice on next steps…pull the exhaust manifolds and take a look in the cylinders, pull the timing covers and check for some broken guides. What could have failed on this motor for someone to diagnose it as needing replacement.
