multiple misfires, runs good, then misfires again
did another trip from detroit to tornto, car ran great as usual.
suddently when pullingot into a driveway extremely heavy misfires car shakes violently. shut it down, doesnt restart.
Finally got it restarted, revved it a few times, got a bunch of blue smoke out the exhaust, but then it smoothed right out.
Ran good for the remaining 600 miles. THen close to home the following day come off the freeway, and while wiating at a light the same thing, heavy misfires flashing MIL and solid EPC light.
Scanned codes, pressed clear all, re read the codes and this is what I got.
Doesnt really tell me much… Why is it so random and across various cyclinders all of a sudden. Then runs good, then multiple misfires again. Battery is brand new…
Monday,01,May,2017,17:12:08:07205
VCDS – Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WAUPN94EX8N000738 License Plate: JENYBUG
Mileage: 146830km-91235mi Repair Order: pt2
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 1E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN94EX8N000738 Mileage: 146830km-91235miles
02-Auto Trans – Status: Malfunction 0010
03-ABS Brakes – Status: Malfunction 0010
05-Acc/Start Auth. – Status: Malfunction 0010
06-Seat Mem. Pass – Status: OK 0000
07-Control Head – Status: OK 0000
0F-Digital Radio – Status: Malfunction 0010
15-Airbags – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
1E-Media Player 2 – Status: OK 0000
34-Level Control – Status: Malfunction 0010
38-Roof Electronics – Status: Malfunction 0010
46-Central Conv. – Status: OK 0000
53-Parking Brake – Status: Sporadic communication error 1000
55-Headlight Range – Status: OK 0000
56-Radio – Status: OK 0000
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: OK 0000
76-Park Assist – Status: OK 0000
Address 01: Engine (BSM) Labels: Redir Fail!
Part No SW: 4E0 910 552 K HW: 4E0 907 552 A
Component: 5.2L V10/4V FSI ª0040
Revision: 5IH02— Serial number: AUX3Z0G7728452
Coding: 01060009190F0160
Shop #: WSC 94817 999 177420
VCID: 2A5BC12A85E30C1197-807E
4 Faults Found:
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 134740 km
Time Indication: 0
Date: 2016.12.18
Time: 01:20:50
         Freeze Frame:
                RPM: 203 /min
                Load: 58.0 %
                Speed: 0.0 km/h
                Temperature: 72.0°C
                Temperature: 41.0°C
                Absolute Pres.: 1000.0 mbar
                Voltage: 11.049 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 134740 km
Time Indication: 0
Date: 2016.12.18
Time: 01:20:50
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: -40.0°C
                Absolute Pres.: 0.0 mbar
                Voltage: 0.000 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Readiness: 0000 0000
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H03— Serial number: 0111352
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 24472F12E7C7DA61AD-8070
1 Fault Found:
049448 - No Communications with Parking Brake Control Module
U0128 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 146270 km
Time Indication: 0
Date: 2017.04.29
Time: 00:00:46
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT
Component: ESP 5.7 allrad H49 0650
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 2B55C42E8A1915196C-807E
2 Faults Found:
000 - - - Intermittent
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G7728452
Coding: 0410624
VCID: 58BF4BE2EB0F4E81F1-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 14
Mileage: 134848 km
Time Indication: 0
Date: 2016.12.20
Time: 08:16:38
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 758 00200
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348HY077526066
Coding: 0000003
VCID: 224B290AFDD3D451DF-8076
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000043940
Subsystem 3 - Serial number: 0106.08.070000000100010058ÿ
Subsystem 4 - Serial number: 010058ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000129117
Coding: 0041409
VCID: 1C3717F2DFB7E2A115-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133123
VCID: 387FEB624B4FAE8111-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0002
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 275D381E56F1317988-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0129186
Coding: 0000100
Shop #: WSC 00000 000 00000
VCID: 2F6DD03EBE01693940-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 243
Mileage: 143994 km
Time Indication: 0
Date: 2017.04.07
Time: 21:37:37
8 Faults Found:
P0300 - 001 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 01:56:35
         Freeze Frame:
                RPM: 658 /min
                Load: 73.7 %
                Speed: 0.0 km/h
                Temperature: 72.0°C
                Temperature: 37.0°C
                Voltage: 12.827 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 01:56:35
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 00:09:52
         Freeze Frame:
                RPM: 766 /min
                Load: 35.7 %
                Speed: 0.0 km/h
                Temperature: 75.0°C
                Temperature: 37.0°C
                Voltage: 13.589 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 00:09:52
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 00:00:57
         Freeze Frame:
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 72.0°C
                Temperature: 41.0°C
                Absolute Pres.: 990.0 mbar
                Voltage: 11.811 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 146314 km
Time Indication: 0
Date: 2017.04.29
Time: 00:00:57
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 146807 km
Time Indication: 0
Date: 2017.04.30
Time: 20:30:35
         Freeze Frame:
                RPM: 597 /min
                Load: 31.0 %
                Speed: 0.0 km/h
                Temperature: 87.0°C
                Temperature: 18.0°C
                Absolute Pres.: 980.0 mbar
                Voltage: 13.589 V
004874 - Cylinder Disabling
P130A - 001 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 146807 km
Time Indication: 0
Date: 2017.04.30
Time: 20:30:35
