…new rotors, pads and steel braided lines all around. Pressure bleeder was used. My brakes are still spongy. Does the ABS need to be bled as well, if so, does anybody know the procedure.
Thanks in advance.
You can bleed the ABS… Go into the module and do an output test. But from my experience the S8 has pretty low feedback from the pedal. So unless it’s gotten weak that’s from my experience normal.
