As I mentioned before in another thread, I got my car stuck in snow last weekend, and during that ordeal a coolant leak was created somewhere. In my quest to find it, I drove onto ramps today, and let the engine run for a while. No leaks for the first 20 minutes or so, then suddenly coolant comes gushing out of the engine bay. The source appears to be somewhere near the reservoir tank, but possibly lower.
I did find an issue with the plastic Y-hose connector that connects the 2 return hoses to the reservoir input, it pretty much crumbled apart when I went to move it. It was most definitely A problem, but I’m not confident it was THE problem. I’ve ordered new hoses/y-connector and waiting for them to arrive next week, but in the meantime, is there anywhere else I should look? The gushing coolant is coming from somewhere behind the passenger wheelwell. There wasn’t really any coolant up high, which makes me question whether the Y was really the problem before I broke it today. The radiator is fine, the metal piping seems fine, I am having a heck of a time figuring out what kind of coolant lines could be behind the wheelwell causing this problem. Any advice?
