I thought it may have been the oil cooler system as well but last week my buddy said he started the car with all the lines disconnected and the noise was still there. When outside the car its very faint and you really cant hear it. Under the hood if you bend down and listen to the passenger side area you can hear it but the loudest is in the car with the windows up.
Im wondering if its the belt and tensioner as well. BUT they are both pretty new as i put a new tensioner and 6 rib belt on last year when i swapped motors.
Saki i dont think its the manifold because we smoked tested and nothing was leaking.
Any ideas/clues would help at this point. Next idea is to maybe try and isolate to see if it is the tensioner or alternator.
Its driving me nuts. The worse part is sometimes when i stop (at a light or stop sign) the noise is very bad and loud and other times it wont be as bad. And this difference can happen within 50 feet between stops. I almost wonder if something is loose and vibrating really bad. i cant figure it out.
As far as logging, ill see about getting some logs in. Right now im chasing an O2 sensor from the header install (think i need a new one gonna swap sides and make sure codes move with it) and i do have one other small issue, when i first start the car is runs pretty rough. Idles hard like its misfiring but no codes seem to pop up from it. Once the car is warm it runs smooth. I was waiting to figure that issue out once the 02 was in and i changed all the coil packs and plugs (which ill be doing here in a few weeks).
The whine is similar to a pump dying (like power steering) and ive even had one comment that is sounds like a supercharger. The aux radiator delete and oil cooler (along with the IM install) was the only thing we did and it started happening after that so it has to be something related to putting it in service mode and installing it.
