Thanks for the info on the hotchkins, makes sense that this would be needed. I’ll have to think about trying this, because pulling off these bushings every year is a PITA, especially in the rear with the exhaust in the way.
I spent most of yesterday trying to get a a set of pliers that were long/strong enough to unscrew it. Problem was there isn’t enough room to fit a vice grip. So really the only solution are needle nose pliers, which I don’t believe have the gripping power? Or could I try a really long set?
Regarding the screw issue, I’m not sure I follow why it won’t turn the bolt. Take for example a simple case where you have a nut and bolt to fasten two pieces together. Once you get sufficiently tight, you’ll need to hold both in place or turning one will turn the other. In my case I believe the torquing the nut towards the bolt will force the bolt to spin the same direction, right? So could I use a reverse threaded nut?
