Need some help from the experts
Hey guys.
so i brought my Car in last week for a defective windshield wiper motor which was replaced under warranty. they also said there was another error code that i have seen in the past with Vagcom.
lonf story short my wife picked up my car so i was not able to get a explanation of what they did to fix this. this is what was on my printout from the dealer
D: DESCRIPTION ADDED OPERATION UPON INSPECTION DURING GFF THE TECHNICIAN FOUND DTC S PRESENT FOR SEC.AIR CONDITION PRESENT. PERFORM REPAIR WARRANTY EXT.APPLIES. Caused by
RAN GUIDED FAULT FINDINGS AND FOUND SECONDARY ACTI
ON PERFORM TEST PLAN FAULT PRESENT, CHECKED VALUE AND FOUND FLOW FOR BANK ONE AND TWO TO BE AT 0.89 WHICH REQUIRES CLEANING
Installed 06E121119E :WASHER
Installed N 0119078 :COVER
Installed 06E121119C :WASHER
Installed 06E121139H :GASKET
Installed 1K0253141M :CLAMP
DRAINED COOLANT, PLACED VEHICLE IN SERVICE POSITO IN, REMOVED COOLANT PIPES AND HOSES, REMOVED BELTS AND PULLEYS, REMOVED FREEZE OUT PLUGS AND PRESSUR ES WASHED SYSTEM. CHECKED PORTS TO ENSURE CLEANIN G WAS COMPLETE. REINSTALLED COMPONENTS AND ROADTES TED VEHICLE OK
sorry for the caps i had a scan of the document and copy pasted it. i was going to post a pic on AZ but then i realized it would be followed by 13 pages of TD1 questions haha. but in case yes it was all covered under warrenty and i did not revert anything to stock.
thank you!
I believe they had an issue with your secondary air injection system and cleaned it out. They also tore apart your cooling system to get to it.
Isn’t the SAI one of the areas the B8 S4 had a carbon buildup problem? Pressure washing carbon buildup would be cool lol.
This should look familiar…
http://img.photobucket.com/albums/v668/Ookane/WP_20130121_001_zps390e0e8c.jpg
Thats a common issue. The SAI valves get clogged. Its one of the service call issues they are told to look for.
