Hello guys,
Been lurking for a few months now trying to learn as much as a can. Was a previous B6 S4 owner who just purchased a high mileage S6 as a secondary/project car which I absolutely love and hope to get running to as near perfection as I can. A little background on the car:
It’s a 2008 with 155K and a 2 person owned car that I picked up for $6500. That definitely will need a little work to make right. Has a bit of surface rust under the driver’s side sill but otherwise the interior is in great shape. I also have yet to find any major oil leaks. Previous owner had it for 9 years and although the carfax lists the same Audi dealer repetitively for service the past 9 years it doesn’t give me any details outside of short descriptions like “45K service.” I’ve contacted the dealership in hopes of getting more detailed records to assist as I being my journey with restoring the car as best as I possibly can. They also confirmed that the intake was not replaced nor was any carbon cleaning performed. I also believe I was told the previous owner gave the car to his father at some point who let it sit despite still having it serviced.
Prior to purchase I scanned using VCDS and without any major codes and after 2 visits and the guy putting on new front wheel bearings and 4 tires I pulled the trigger. After 2 days of driving I had coolant laying all over my driveway which I’ve traced to a cracked coolant res. So currently I’m working to get that resolved. I’m also in the process of pulling off the front core-support to more easily access the belt and pulleys as only half of the belt exists and all the pulleys, belt tensior are all very rusted. Will be replacing all of these parts including a JHM crank pulley. So rather than fight with the 6-8 inches I’ll get from service position I’d like to be able to work freely without interference. From there I’ll likely try to get the intake off to do carbon cleaning and add spacers as well.
So that leads me to a few questions I have, 1 relating to the intake removal and 2 pertaining to the last part of me pulling off the core support of which I’m very close to completing:
1.) The intake bolts are extremely rusted (valve cover ones are even worse) - some of which I can tell right off the bat have rotted to the point I won’t be able to get a bit on there. What would my options be for extraction in this case? Drill them out?
2.) I’ve also stripped a bolt trying to remove the line labeled #1 from the radiator in my screenshot. What line is this? And can/should I try and drill this out?
3.) Lastly was just hoping to confirm what #2 was in the screenshot.
http://
Appreciate any feedback on these would be much appreciated.
