New Member! and first problem post
Hey all! my names jeff and i own a 2004 Nogaro S4 with 130k on the clock. its my second B6 S4 so I’m kinda familiar with some things on these cars but not everything, hopefully you guys can help me out more than OTHER forums have.
So heres the issue!
I had a friend driving behind last weekend and he informed me that the i was having blue smoke come from my exhaust while cruising on the highway and backroads.
I’ve recently changed the PCV and cleaned the IM as well as do the oil check valve service and installed JHM IM spacers.
the tops of some valves were a little wet with oil, but no buildup at all. Sunday i did a compression test and the results did make me fee to good that night. but after thinking about it i think it’s my valve seals crapping out.
Here are the results
These were done dry after the engine sat for an hour and half after a long drive.
Bank 1
Cylinder 4) 120psi piston head dry plug had buildup
Cylinder 3) 130psi piston head dry
Cylinder 2) 115psi Piston head dry
Cylinder 1) 130psi piston head wet
Bank 2
Cylinder 5) 85psi very wet plug had buildup
Cylinder 6) 125psi piston head dry
Cylinder 7) 150psi piston head dry
Cylinder 8) 100psi spark plug had buildup
i also scoped the cylinders. 1,5,8 looked like this
what it means i have no idea but maybe its from the valve seals dripping down
https://scontent-lga.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/10426329_10152759872626538_9103527835589971977_n.jpg?oh=4a8c20ff9fee4be65606d52156d38b2b&oe=557D3C68
any thoughts on this word be greatly appreciated!
