Recently, I had the brake pad warning light flash up for like a day and it disappeared. I thought for sure it was the rear pads as they have at least 40K miles on them. I drove for another week and then noticed I’d put a groove in the center of the rotor as the pads on the driver’s side had worn down to the rivets.
I went back and forth between Girodisc and JH Motorsports and in the end, with a Black Friday sale sealing the deal, I went with the JHM rotors. The Girodiscs have the advantage of being full floating vs. semi floating but the $300 price difference covered the pads and then some. Both are approximately the same weight and both are lighter than the OEM rotors.
I had EBC Reds on the rear which were honestly great. Somewhat low dust, no noise, no complaints really. But I knew I’d be switching over to Carbotech 1521 street pads once it was time. I ordered a set of those up and even though they weren’t in stock, I had them four days later. They’re made right here in the U.S. and I’ve used them on cars in the past with great success.
I’ll be producing a video on changing the rear and front pads although there’s already one good tutorial on this forum. As long as you have a VCDS or similar, it’s a very easy procedure.
I haven’t had a chance to bed in the pads/new rotors just yet but will do so as soon as I swap in new front brake pads. I can already tell the Carbotech pads will be a nice improvement and match the bite of the CCB fronts.
The brake pad light was in fact, a coincidence where the rear brakes were concerned. It wasn’t the rears telling me they needed changing as I found the wear indicator on the rear pads had been cut/spliced together so there was no dash warning light.
I now have the brake pad warning light on full time and given the rear sensor is effectively non-functioning, I knew it was the front brakes. I measured the pads with calipers on both the driver’s and passenger’s side and they’re not down to their minimum thickness. Not taking any chances, I went about ordering new CCB pads.
I’d had my heart set on the Pagid RSC1 pads which are about as pricey as the OEM pads, around the $500 mark. While searching for the best price, I stumbled onto CCB pads made by Brembo. Hadn’t seen these before and I was able to find them for a bit over $100 for a set! I also purchased new brake pad wear sensors and with expedited shipping, the whole lot came out to a bit over $200. At the very least, if they suck, I’m out $117 and shipping for the pads.
The pads are Brembo part number P65016. They have an even less expensive set which is part number P65016N. I went with the former.
They should be here on Friday and I’ll report back when I have some feedback on them. A good low-cost alternative will be a great thing for CCB-equipped cars.
