Well after lurking heavily on here the last couple weeks, it’s time to finally post something!
After loving these cars for a long time, I just bought myself a black 2007 S6 with 81,000km a couple weeks ago and love it! I used to have a 2005 A6 S-Line with the 4.2L and had a lot of fun with it, however this is a totally different beast!
After combing through here it became apparent that aside from the performance upgrades I’ve been eyeing, I’ll also need to do a good round of maintenance. I then also a few days ago got a check engine light, code P2006 bank 1 flaps stuck closed. Up until that point it had been running great and smooth, little to no misfires.
I got my hands on the last 25,000km of service records for it and combed through everything and did find the motors on the IM have been replaced a couple times so I’m going to go ahead and assume it is shot and needs replaced. The previous owner had an extended warranty so it seems everything was kept up on fairly well but definitely hasn’t had the full once over or a real carbon clean (just one of the spray a bottle in the intake type has been done). I want to do everything right the first time and just do most of it in one round so everything is all fresh going forward and I can just enjoy the car!
So the list I’ve compiled is:
- Carbon Cleaning Tool Kit X 2
- Carbon Cleaning Solution X 2
- Intake Manifold
- JHM Intake Spacers With Additional Pair Of Gaskets
- Coil Packs (OEM) X 10
- Spark Plugs (OEM) X 10
- JHM Cleaned, Flowed & Resealed Injectors
- JHM Lightweight Crank Pulley
- Serpentine Belt (OEM)
- Oil Separator to Valve Cover Vent Hose (OEM) (Current one is cracked)
- Both Valve Cover Gaskets (OEM)
- K&N Air Filter X 2
- JHM Cat-Back Exhaust
- JHM Tuning
- JHM Flashing Cable
I’m going to do all the maintenance and associated upgrades first and have it all cleaned up and running perfectly first and get some KM in then I’ll add in the exhaust and tune. Like I said though, until the check engine light it was running very nicely so I don’t have anything to give me major concerns but I’d rather go a little over the top on freshening things up while I’m already in there then have to go back and tear things down again.
One question (among the many more to come) is in regards to VAG COM and what my best option will be for that.
I came across this one on ECS that’s currently on sale for $150 but what I’m wondering is if this is as powerful and equivalent to the Ross-Tech system or if it will have limitations compared to it. Or if there’s a better option that either of these, just let me know.
I’m super excited to get playing with this thing, it’s a lot of fun even in it’s stock form and can’t wait to wake it up and have even more fun! Also I’ve been loving the fun of a powerful NA engine, I forgot how much fun not having turbo lag and an instant significant amount of power can be! I haven’t really went deep into a gas performance build as I’ve been playing with diesel trucks the last while so will be fun to switch it up and I’m sure I’m going to benefit greatly from all the informative posts on here to help me through a lot of these jobs!
Anyways if there’s anything I’m missing that should be included in this list, just let me know.
