new wheels test fit
So, I found out on Friday that the stock S6 wheels will not fit over the 18z I am installing on the S6. No problem, Ill swap the OZ Superleggeras over from the A6, I thought. Well, Friday afternoon on the dyno the tire started shedding tread on the OZs. So, the search started for some new tires. After looking around a bit, I found a set of 20 inch OEM peelers. I already had a pair of tires for them, so decided to pick them up for the S6, and save the OZ for winters. They weigh a ton, but look pretty good. I did a test fit on the A6 this afternoon for fun.
http://gp1.pinkbike.org/p4pb9631462/p4pb9631462.jpg
http://gp1.pinkbike.org/p4pb9631455/p4pb9631455.jpg
http://gp1.pinkbike.org/p4pb9631460/p4pb9631460.jpg
http://gp1.pinkbike.org/p4pb9631461/p4pb9631461.jpg
http://gp1.pinkbike.org/p4pb9631459/p4pb9631459.jpg
http://gp1.pinkbike.org/p4pb9631457/p4pb9631457.jpg
http://gp1.pinkbike.org/p4pb9631454/p4pb9631454.jpg
http://gp1.pinkbike.org/p4pb9631452/p4pb9631452.jpg
http://gp1.pinkbike.org/p4pb9631451/p4pb9631451.jpg
Fronts are fine at et22, and dont rub even with extreme lowering (but lots of fender work). Rear fitment is too aggressive with the spacers I had on the car, which leave it at et12. Likely et17 would work ok out back. Will have to see when they are mounted on the S6.
