I dont want to beat a dead horse but a thought came to me to go ahead and compare the vagcom time stamps of a stock car, a stage 1 level car, and your log.
So your log went from 2622rpm to 6287 rpm with the following time stamps…
26.36
27.74
29.11
30.49
31.88
33.25
34.63
36
So the car did a third gear pull traveling a total 3665 rpms of rev band in 9.64 seconds.
Here is a log of a car first at a stage 1 level of tune and after the marker is a second run on a completely stock tune.
https://drive.google.com/file/d/0B2qLNaD2PEmkZG41NlRMLV83Nzg/view?pli=1
At stock the car traveled from 2583rpm to 6277 rpm or a total of 3694rpms in a total of 8.08 seconds. I made sure to crunch the data in favor of your car as your car traveled slightly higher in the rev band and for a bit fewer rpms.
At the stage 1 level the car traveled from 2591rpm to 6290rpms or a total of 3699 rpms in 7.56 seconds.
That data is also confirmatory. I’d stick with the suggestions to try a different fuel and send all this data to your tuner once you try out a new fuel and datalog that as well. Hopefully a new 93 gas station will help.
Mike
