Axel
Good that you posted this here. There isn’t anything wrong with your car… when I had the S4 at my house I would keep it in my heated gargae the result was no blip on start up. When I had it at my friends house it was outside and depending on the temps it would blip on startup
With the JHM tune your oil pressure and the outside temp will signal your car to either iddle high or to just low iddle … it always seems like its going to stall at low iddle due to the idle stabilization that happens on the b7 cars on start up… You know the woot woot that normally happens.
So if your car dosnt require a iddle blip on start up that’s good. Bigger injectors might make it more noticable and the odd b7 fuel issues don’t help… I remember I needed a pump adjustment when I got headers… seems the b7 cars are just funny that way.
All In all sounds like your ok and there is nothing to worrie about you should even feel better that your car isn’t requesting the higher rpm on start up. Start-up is the most crucially important time when it comes to motor ware so having the car keep the low rpm is good. It should mean your oil pressure is good
