So i got my first audi today and i bought it with some problems. I knew that it had the yellow oil sensor light on. I looked around the best i could on the site about it with no luck thats why i posting. I went to the local VW dealer and told him that i needed a oil sensor. I told him that the yellow light was on so we asked a tech what sensor to order. We ended up with 1j0-907-660-b i hope this is it. Well besides that i think the guy i got it from killed the codes because i got it home and it started to misfire very bad i have light access to a snap on scanner that has a VAG module. I got random multiple misfire and system to lean! so i looked at the vacuum lines seen a few that are cracked. I replaced them and found one into the intake that was chewed up so i fixed it and then broke the check valve! Now it runs fine but check engine light still same codes. attached to the intake is a large disc that looks like it comes off the valve covers and it’s hissing a lot. If I put my finger on the disc, it will stop then when I lift off it lets a ton of air out. I talked to a few audi tech and they said they never seen them go bad.
So long post short did i get the right part. Should I change the millennium falcon looking disc off the intake? Does it allay hiss?
I have a 2002 Audi A4 3.0 Quattro auto with about 116k on it
thanks
