Installed tapatalk . The app looks great .
So , nitrous and the rs4 worked great for me .
It was a time for experimentation and while working on the hardware we also tried quite a lot of ecu tunes too .
I installed a progressive nitrous controller from wizard of nos . The name is kind of funny but their products are pretty good . The controller was hardwired in the cars wiring loom . There were quite a lot of safeguards : throttle butterfly sensor , throttle pedal sensor , fuel pressure sensor ( low pressure) , nitrous pressure . The kit had a delay for nitrous and a time ramp up (as opposed to rpm ramp up) .
I started with 25 hp jets and I couldn’t really feel anything .
Then I went for 50 hp and I thought I would add an extra layer of safety so while on s mode and full throttle , the target afr was set to 10.5 . That may have sacrificed a few hp (although not as much as you might think) but gave me some perceived safety .
The setup was kind of mundane to be honest . There were no special parts or inventions . A line from the trunk to the engine bay for nitrous and a t piece in the fuel line before the stainless lines in the engine bay . Those both went into solenoids which were hidden in the compartment where the wiper motors and ecus are . Then you got two lines that went into the nozzle that was plugged in the rubber throttle elbow before the throttle body .
I’ll look for some pictures . they might be on photobucket and my account is the same duud40 . Have a look .
The stock ecus were unexpectedly friendly to nitrous but spark plugs and coils were less so . Changed to bkr8eix and set spacing (cant remember size) as well as new plugs and that was that .
I remember that one time I forgot ( lol ) to connect the electrical connection to the fuel solenoid . I had 75 hp or 100hp nitrous jets and made a run and logged some vag com stats . Bottom line is : the ecu compensated the extra fuel . I was then very happy to have set target afr richer .
One more thing to mention : the lines were not braided , they were nylon lines that had a small inside diameter . That meant restriction but also meant small interior volume . When I went over 100 hp I added a second nitrous line to be able to supply enough of it .
Overall I had fun and the car behaved very well (with nitrous at least ) . Went for a bigger bottle that I never used (20kg vs 15 lbs ) . At the highest setting which was 150hp the manifold would freeze over and turn white
cool for wowing friends .
I was expecting a fast and furious type of reaction but the result was always silky smooth . Small internal volume , progressive time ramp up and a really good intake manifold design made the system very easy to use .
At the time I really sucked at videos and only managed some crap vids .
I would describe it as opening the throttle more . Like in off nitrous mode the throttle goes to 75% and when on nitrous it goes to 100% , not like turbo , not like a supercharger , just silky smooth 25-30% more power .
Let me know if you need anything else .
