Now Available: JHM B8/B8.5 Porsche (Brembo) 382MM Front Big Brake Kit
JHMotorsports is pleased to introduce a low cost, 100% Bolt On, Front BBK (Big Brake kit) solution for your B8 A4-S4 A5-S5 that uses the popular Porsche Brembo 6-Piston Caliper, also commonly known as the 19Z!
https://jhmotorsports.com/products/pictures/B8-382-BBK/JHM-S5-B8-BBK-382MM-Detail.jpg
Video:
https://youtu.be/-ClzGmjVo4w
https://jhmotorsports.com/products/pictures/B8-382-BBK/JHM-B8-382mm-BBK-detail-1.jpg
https://jhmotorsports.com/products/pictures/B8-382-BBK/JHM-B8-382mm-BBK-detail-2.jpg
INCLUDES:
2x - JHM 2-piece Lightweight Slotted Front Rotors
2x - JHM Caliper Brackets with Mounting Hardware
2x - BRAND NEW OEM Porsche (6-piston Brembo) Calipers
2x - Stainless DOT Approved Brake Lines
1x - Set of OE Pads Brake Pads
1x - OEM Brake Pad Sensor (Driver Side Only)
1x - Liter Pentosin DOT 4 Synthetic Brake Fluid
INSTALLATION: This is a COMPLETE 100% bolt on Big Brake Kit for the B8 Chassis. This kit requires ZERO modifications, cuts, grinds, splices, etc. making installation quick and simple. NOTE: The stock Dust Shields will need to be removed for proper clearance
OEM S4-S5 Rotors vs. JHM Lightweight Rotors (A4-A5 vehicles will yield greater results)
-Rotor Weight: Stock = 23lbs(each), JHM = 24.1lbs(each) - Only 1lb heavier for a MUCH larger rotor
-Rotor Cooling Air-gap: Stock = 11.5mm(.450"), JHM = 18.5mm(.728") - LARGER for better cooling
-Rotor Cooling Center Fin Design: Stock = One Direction Airfoil (one side pumps the air from the inside out and the other side pumps the air from the outside in), JHM = Airfoil (side specific rotors that both pump the air from the inside out) - EQUAL EFFICIENCY for equal cooling
-Rotor OD: Stock = 345mm(13.6"), JHM = 382mm(15.039") - 1.43" LARGER
-Rotor Thickness: Stock = 30mm(1.18"), JHM = 34mm (1.33") - 4mm (.15") LARGER
-Bolt pattern: - SAME (fits like an OEM rotor would)
Why the Porsche Cayenne caliper?
With its 6-piston design and MASSIVE brake pads it is a strong performer. Also it bolts right up to your spindles using our JHM CNC’d Caliper Brackets. All you need is the included bolts, brake lines and JHM rotors and you have a 382mm Big Brake Kit.
Outer ring specs:
We worked closely with a race brake manufacturer that supplies many NASCAR racers and a couple major brake kit companies. Due to their expertise we chose to have them build us the outer rings to our specs to fit the B8 Chassis. 12 attachment points for durability and strength.
https://jhmotorsports.com/RandD/JHM_Engraved_Rotor_Hat_Closeup.JPG
Center hat specs:
We CNC machine the Aluminum center hats in house based on their recommended materials and thicknesses for durability. 12 attachment points for durability and strength. We also engrave JHM in them in 3 locations equal from each other, it looks clean and doesn’t jump out or look tacky.
[B]Custom Caliper Colors Available!
[/B]
https://jhmotorsports.com/products/pictures/B8-382-BBK/JHM-B8-382mm-BBK-detail-3.jpg
Click Here For More Info: https://jhmotorsports.com/shop/catalog/front-bbk-big-brake-kit-jhm-382mm-porsche-brembo-piston-for-b8-a4-a5-s4-s5-p-3722.html
Thanks to everyone for your continued support! If you have any questions or would like help placing an order, please don’t hesitate to shoot us an email or give us a call!
Sales@JHMotorsports.com
209-968-0077
Jake
