Introducing the JHMotorsports Stage 1 B8-S5 4.2L Supercharger Kit!!!
The JHM Stage 1 Supercharger is hands down the most cost effective supercharger solution for the B8-S5 4.2L. With common bolt-ons and supporting hardware, we have repeatably achieved high 11 second quarter mile runs, with 118MPH trap speeds!! With performance like that, your seemingly unsuspecting two door German coupe becomes a definite force to be reckoned with.
https://www.youtube.com/watch?v=QZksY3FYVvU
FEATURES AND SPECIFICATIONS
a Our JHM Stage 1 Supercharger Kit for the B8-S5 4.2L will make 100-120 wheel horsepower (WHP) over your car’s current configuration. Your current modifications, the dynamometer (dyno) used, temperature, elevation, and octane of gas will all effect the exact amount of power gains.
Our Supercharger Kit features a Vortech V3 Si Centrifugal Supercharger Head Unit that is good for up to 800 horsepower! (Unchecked, this amount of power would be too much for a stock B8-S5 4.2L motor. Through our extensive development and testing process, we were able to limit the output of the supercharger to levels safe for the stock motor through hardware and tuning.) The V3 Si blower is a self-contained unit featuring quiet, helical cut gears. The only time you hear noise from the blower is at idle and low speeds. At wide open throttle, you hear nothing but the raw power coming from your JHM Supercharged S5.
https://jhmotorsports.com/products/pictures/supercharger/B8-S5/SC-installed-detail.jpg
The JHM Stage 1 Supercharger Kit also includes our JHM Supercharger Mounting Brackets that were designed and are made in-house. These brackets are made from reinforced steel, laser cut, and then powder coated black for a clean installation.
In order to insure the longevity and durability of the belt and pulleys on the S5, we upgraded the OEM belt and pulleys to a 6-rib system with our JHM 6-Rib Accessory Belt Conversion Kit. This Conversion Kit features 3 JHM Supercharger Kit specific pulleys including an Alternator Pulley, a precision balanced Crank Pulley, and a Supercharger Pulley good for 5 to 7 pounds of boost (exact boost levels will vary depending on your exhaust system, other modifications, and environmental factors).
https://jhmotorsports.com/products/pictures/supercharger/B8-S5/SC-installed-detail-3.jpg
Due to the compact engine bay of the V8 S5, we had to locate the Vortech Supercharger Head Unit off of the passenger side of the motor, below the headlight. We created a number of different proprietary parts including our JHM Supercharger Kit Silicone Inlet and Outlet Hoses. The Inlet Hose is made from reinforced silicone to prevent collapse under vacuum. The air intake is filtered through a JHM Supercharger Kit specific K&N high-flow, conical air filter.
We are currently working on JHM Supercharger Kit add-ons that will allow you to use more of the supercharger’s power capabilities. Stage 1+ (Intercooled with upgraded fueling and a smaller pulley, safe for stock motors). Stage 2 will require a built motor for engine safety and longevity.
https://jhmotorsports.com/products/pictures/supercharger/B8-S5/SC-installed-detail-2.jpg
For more information and introductory pricing,CLICK HERE https://jhmotorsports.com/shop/catalog/jhm-supercharger-kit-for-b8-s5-42l-fsi-v8-stage-p-3432.html
If you have any questions or would like help placing your order, please don’t hesitate to give us a shout!
Sales@JHMotorsports.com
209-968-0077
Jake
