At the title suggest I’m in the NYC area and having a hard time finding a decent Audi mechanic.
Anyone here familiar with the area enough to suggest a mechanic?
What all work do you need done. the NYC and jersey area is really hard to find a good honest knowledgeable mechanic. I have heard horror storys about guys getting ripped off out there. I think depending on the work you need there are several good shops but they might be limited as to there ability to do work.
I am in northern NJ, I have used Eurotech in Mahwah and RSW in Green Brook. I had issues with both. Feel free to PM me with any questions, I can give you more details on my experiences with them.
I recently found Drive Auto Works in Mountainside, I’ve only had oil change done there, wanted to check the place out, I was very happy with what I saw and heard. Currently waiting for JHM exhaust to be delivered there for installation. I’m also going to have them do some other work with the exhaust install, I’ll post when I get the work done.
I think I’m about to develop my own horror story.
Things I need to do at the bare minimum:
- Find and correct an aggressive oil leak.
Carbon Clean
Install Intake spacer and replace pcv valve
Half my motor is misfiring so troubleshoot that to determine if it’s a vac leak or I need to replace fuel injectors due to carbon build up.
justincredible:
smith6:
Anyone here familiar with the area enough to suggest a mechanic?What all work do you need done. the NYC and jersey area is really hard to find a good honest knowledgeable mechanic. I have heard horror storys about guys getting ripped off out there. I think depending on the work you need there are several good shops but they might be limited as to there ability to do work.
Carbon Clean
oh man that’s a big important list. Oil leaks can be in such difficult spots as the oil pan and you need to be a proficient shop to do that well. I think no matter what if your pulling the intake to do the carbon clean it would be smart to catch the injectors as almost EVERYONE has injector issues.
While I find a trusted mechanic in my area here’s a recent scan. Appreciate any thoughts & comments.
Chassis Type: 4F (4L0)
Mileage: 145880km-90645miles
05-Acc/Start Auth. – Status: Malfunction 0010
07-Control Head – Status: Malfunction 0010
08-Auto HVAC – Status: Malfunction 0010
0F-Digital Radio – Status: Malfunction 0010
61-Battery Regul. – Status: Malfunction 0010
65-Tire Pressure – Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H14— Serial number:
Coding: 01050009190F0160
Shop #: WSC 02335 785 00200
VCID: 221EE00888C18C771BD-8076
3 Faults Found:
008198 - Intake Manifold Flap; Bank 1
P2006 - 008 - Stuck Closed
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145542 km
Time Indication: 0
Date: 2017.04.04
Time: 11:21:59
Freeze Frame:
RPM: 645 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 18.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.208 V
P2006 - 001 - Stuck Closed - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145542 km
Time Indication: 0
Date: 2017.04.04
Time: 12:14:06
Freeze Frame:
RPM: 2752 /min
Load: 81.5 %
Speed: 37.0 km/h
Temperature: 104.0°C
Temperature: 44.0°C
Voltage: 12.954 V
P1923 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145889 km
Time Indication: 0
Date: 2017.04.13
Time: 19:16:38
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 19.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.049 V
Readiness: 0000 1000
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200683228
Coding: 0000007
Shop #: WSC 08252 444 128310
VCID: 2412E61092D58247691-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
1 Fault Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 26
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 361BE077511513
Coding: 0010003
VCID: 323E1048D8211CF7EBD-8066
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000676262
Subsystem 3 - Serial number: 0121.02.070000000100010821ÿ
Subsystem 4 - Serial number: 010821ÿ
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 6
Reset counter: 93
Mileage: 144827 km
Time Indication: 0
Date: 2016.12.29
Time: 14:00:59
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000700333
Coding: 0524330
Shop #: WSC 08353 444 12211
VCID: 1C62DEF0AAA5BA87D11-8048
1 Fault Found:
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 145435 km
Time Indication: 0
Date: 2017.02.10
Time: 08:09:49
Freeze Frame:
Temperature: 48.0°C
7 Faults Found:
008199 - Intake Manifold Flap; Bank 2
P2007 - 008 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 145813 km
Time Indication: 0
Date: 2017.04.12
Time: 15:51:07
Freeze Frame:
RPM: 847 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 111.0°C
Temperature: 46.0°C
Voltage: 10.668 V
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145813 km
Time Indication: 0
Date: 2017.04.12
Time: 15:51:35
Freeze Frame:
RPM: 1159 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 24.0°C
Voltage: 12.700 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145813 km
Time Indication: 0
Date: 2017.04.12
Time: 15:51:35
Freeze Frame:
RPM: 1159 /min
Load: 49.4 %
Speed: 0.0 km/h
Temperature: 21.0°C
Temperature: 24.0°C
Voltage: 12.700 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145813 km
Time Indication: 0
Date: 2017.04.12
Time: 15:51:56
Freeze Frame:
RPM: 1127 /min
Load: 37.6 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 25.0°C
Voltage: 12.827 V
000777 - Cylinder 9
P0309 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145813 km
Time Indication: 0
Date: 2017.04.12
Time: 15:51:56
Freeze Frame:
RPM: 1127 /min
Load: 37.6 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 25.0°C
Voltage: 12.827 V
008197 - Intake Manifold Flap; Bank 2
P2005 - 002 - Stuck Open - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145814 km
Time Indication: 0
Date: 2017.04.12
Time: 15:56:44
Freeze Frame:
RPM: 697 /min
Load: 18.4 %
Speed: 0.0 km/h
Temperature: 62.0°C
Temperature: 26.0°C
Voltage: 12.446 V
000784 - Cylinder 10
P0310 - 001 - Misfire Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145889 km
Time Indication: 0
Date: 2017.04.13
Time: 12:43:01
Freeze Frame:
RPM: 1130 /min
Load: 56.1 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 18.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.462 V
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01034820450000
Coding: 4618269
VCID: 2E060438CC1938178F5-807A
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 161
Reset counter: 60
Mileage: 144790 km
Time Indication: 0
Date: 2016.12.16
Time: 18:45:58
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000019096
Shop #: WSC 09401 444 82758
VCID: 2310E50C97DB857F10B-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 VA0320323N
Coding: 34463039313531303544205641305641303332303332334E
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 29
Reset counter: 255
Mileage: 144497 km
Time Indication: 0
Date: 2016.12.05
Time: 08:35:05
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 255
Mileage: 144827 km
Time Indication: 0
Date: 2016.12.29
Time: 13:39:27
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 255
Mileage: 144827 km
Time Indication: 0
Date: 2016.12.29
Time: 13:39:38
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 9
Reset counter: 255
Mileage: 144827 km
Time Indication: 0
Date: 2016.12.29
Time: 13:39:48
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 144827 km
Time Indication: 0
Date: 2016.12.29
Time: 13:39:58
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900042496
Coding: 0062725
1 Fault Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 45
Reset counter: 67
Mileage: 144894 km
Time Indication: 0
Date: 2017.01.08
Time: 12:46:15
Freeze Frame:
(no units): 20.0
Temperature: -5.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
End----------(Elapsed Time: 02:04, VBatt start/end: 11.6V/11.6V)-----------
so i ended up going with a JHM authorized dealer named Drive Auto Works in Clifton NJ.
The car has been there for a week and a half now and so far the customer service has been great.
They’re doing the following:
- Water Pump
Oil Level Sensor
JHM Light weight Pulley
Carbon clean
JHM Intake Spacers
PCV Valve
JHM Block off plate kit For SAI
JHM Oil Separator Heater Bypass
JHM Tune
The car has been there for a week and a half now and so far the customer service has been great.They’re doing the following:
- Water Pump
Oil Level Sensor
Carbon clean
JHM Intake Spacers
PCV Valve
JHM Tune
That sound similar, I think you will love that maint and mods, from what I hear at least.
- Water Pump
Oil Level Sensor
Carbon clean
JHM Intake Spacers
PCV Valve
JHM Tune
That’s a very good list. Let us know how it turns out. We always love to hear those after tuned stories.
Update:Car’s been done for over a week except for the JHM tune.
Apparently there is an issue with the login information from JHM and the local shop (JHM Authorized Dealer) can’t get the files from them.
Anyone ever had this issue?
I did mine at home, and it’s been a while, I do remember a few steps to setup the login, one was a VPN connection. I’m not sure where they were having the problem, I do know there needs to be a VPN connection before you get to the server login to download the file. I hope that helps, sucks to see you weren’t able to get the tune, it’s a game changer.
Apparently there is an issue with the login information from JHM and the local shop (JHM Authorized Dealer) can’t get the files from them.Anyone ever had this issue?
That sounds odd. I too have flashed at home and didn’t have any issues. I have flashed quite a few times.
Well the shop say they can’t download the file from JHM. They’ve been trying for over a week. JHM sent instructions to them but after following each step they can’t access the file. I hope they’re not yanking my chain. I want to call JHM but the shop ordered the tune I have no info.
What they are telling you makes no sense. If they have internet they have the JHM tune. I would absolutely call JHM. Ask to talk to Dru. They don’t have to down load anything if they are a JHM dealer and have flashed in the past all they do is hook up to your car and the rest is mostly automatic. And like I said if they have internet then they have everything they need.
I would call and just say the name of the dealer and what you have going on. JHM is really really good when it comes to giving customer service.
