Hello.
I did quite a bit of work after I purchased my 2008 S6; (valve cover gaskets, oil filter housing o-rings, valve cover gaskets, etc).
The last think that I did was reseal the oil pan as it looked like it was leaking.
But I seem to still have the oil leak. I think it is the oil cooler on the passenger side of the engine. From what I can see, that is the only thing that could be causing the leak.
I am going to change out the o-rings on it. From the Bentley manual, it says you have to remove the radiator, then the belt and belt tensioner, the the alternator, then a bracket, and then you can get to the oil cooler.
How many o-rings does it require? Also, do you need to drain the oil to do this work? Any thing else that I might need to know?
Thanks.
