Oil Cooler upgrade?
Is there a company out there who sells an upgrade aftermarket oil cooler for the B7 RS4?
Summer is around the corner and I figured a better oil cooler would be a nice treat for the car?
iirc JHM was working on something a while back, I recall talking with Dan about it in probably 2010.
should be fairly straightforward on the rs4 since there is already the factory cooler vs say the s4 where the oil never leaves the engine and a mocal plate wont work b/c of the top mounted filter
You have to customize an aftermarket oil cooler from someone like Setrab. There have been a couple guys who have done this in conjunction with deleting their auxillary rad and adding an intake snorkel on the passenger side to increase air intake. Koolade has done this.
My oil cooler is going (leaking connection) and I asked JHM recently about a kit they might have. The reply was vague (even after a clarification email), but they said they only have one for the S4. I think it is what is used in their SC kit. Like I said, 3 emails and their answer still didn’t make sense to me.
There should be a couple.
JHM sells one because their supercharger eliminates the aux radiator. Although that is in beta so ‘sells one’ isn’t the right answer.
I know Mick and Blake have done this. Pretty sure if you search on QW and/or AZ you can find some info. It isn’t an off the shelf solution, with the fittings, etc. But as someone else said, they deleted aux radiator and upgraded oil cooler with a Setrab unit. On Mick’s car, it definitely kept the max temps down, and the recovery time was much shorter.
^^^vote to ban for mentioning other websites
STOP RECRUITING JAREDS!
(just doing the quattroworld/audiworld standard post to make you feel at home)
As others have said, two of us have upgraded to a larger setrab unit. However, I still believe the key to lower oil temps on the RS4 lies in fabricating a block-off plate for the oil cooler block on the side of the motor. I’ve documented the oil flow through the areas in question. This will allow your factory oil cooler to be used 100% of the time vs. the oil block (that’s cooled by your coolant). I sourced an extra oil block from CKS, sent it off to have a plate made, but haven’t heard anything since. I still bug him from time to time to get one cut, as it’s a really easy part to make…someone just needs to move forward with it…
Very interesting info, surely appreciate the feedback. ;D
This was also recommended to me: CT-29 coating for radiators.
http://www.calicocoatings.com/industries/coating-solutions/automotive-racing/
I’ve only seen this applied on Porsche w/o any factual data. Any thoughts?
Cheers
With air-cooled P-cars, you only have so much surface area up front for the oil coolers, and they’re usually using all that area, hence finding ways to increase heat-transfer. In our situation, it’s a mechanical issue where oil is bypassing the oil cooler altogether under high RPM… Because there are two paths the oil can take, it’s taking the path of least resistance.
necro bump.
Koolade, what have you done regarding the block off plate you mentioned? Have you changed anything regarding your oil cooler?
necro bump.
From what I gathered I dont think the block off plate is needed unless your tracking the car.
Block-off plate didn’t appear to do anything for oil temps above 7k rpm. I just picked up the last fitting I needed to connect an oil pressure gauge to the car and start gathering more data. I’m still running a huge setrab oil cooler. Not really any further into finding a solution other than just continuing to eliminate variables.
Always love to hear the updates and anything you find out. sounds like your digging really deep. interested to hear more when it becomes available
