Oil in multiple cylinders - constant misfires, no power etc..
Hey guys,
I was able to clear up my initial rough idle by fixing a vac leak post throttle body as it mated up to the intake plenum. Was also able to clear up misfires by changing all coils and placing in new plugs. Had a full carbon cleaning done as well. After all this work the car was CEL free for about two months.
Suddenly one morning after the car warmed up I was on the road and noticed a lack of power, shuddering misfires when on the slightest bit of throttle and the CEL came back on. I have little to no power with moderate throttle. CEL flashes.
I pulled and inspected the coils and plugs. cyl 2-4 and 7-8 plugs covered in oil… enough to coat the socket when extracting the plug. Coil packs covered as well, though I don’t believe fully up to the electrode.
I’m assuming this is the cause of my misfires and lack of power/rough acceleration.
I’ve hunted around for valve cover gasket sets and since my S6 has a 3/22/2007 build date, they no longer manufacture full gasket kits for both banks. I would need to buy a full valve cover with installed outside gasket and separately purchase the inside. Oddly enough the left bank is available as the standard set without valve cover.
Dealer wants $530 - ECS/others are back ordered without any delivery date.
Before consider this expense, is there any way to inspect and determine if the leak is in fact from the VC gasket around each plug cyl or could it be from the lower gasket where the head mates to the block?
Can anyone provide insight?
Has anyone had to replace their VC gaskets?
Hoping to make a decision quickly to fix this weekend if I can have parts in time.
