Hi all,
I’ve been seeing some oil in the spark plug holes on the driver side for a couple of months. I removed all the coil packs on the driver side ~2000miles ago and found about an ounce or two of oil in cylinder #7 (I think, second cylinder closest to the firewall). All the other spark plug holes were dry so I cleaned it up and replaced that coil pack.
I checked it again just last week (after driving ~2000 miles) and found that all the spark plug holes on the driver side had oil in them. Again not a lot, the cylinders that had the most were just enough to get the bottom of the coil packs wet with the oil but I’m concerned it’s getting worse.
My initial thought was the valve cover gasket was leaking but after looking at it for a while I’m not completely sure. I took a picture and was wondering if anyone could provide some input.
http://audirevolution.net/addons/albums/images/476347997.jpg
If I’m looking at the valve cover correctly in the picture, it is mating with the head where the red arrow is. It seems to me that the oil is coming out further down the spark plug hole where the green arrow is. I couldn’t find information as to a second gasket so I’m confused if this is actually something that comes apart or it’s actually leaking from the valve cover and just looks odd.
Any input would be appreciated!
Thanks!
