Frank85
Here is a link for putting the bummer into service position.
http://audirevolution.net/forum/index.php?topic=3725.0
If you want to take it all the way off you will have to disconnect the AC lines, coolant lines, and PS lines. When removing the headlight washer line from the pump be careful with it, it is pretty fragile and easy to break. I don’t think they are Italian though. Also, there will be a couple of electrical connections that will need to be un-clipped. There are two in the bumper when you pull that part off. To remove the carriage there are also a couple connectors that need to be undone. There are two that are about the drivers headlight. In the link you can see them next the PS reservoir at step 6. You will also have to remove the accelerometers for the airbags. I would recommend leaving them plugged in an just unbolting them. There are yellow sensors on either side of the radiator. You can see the airbag sensor resting on the PS reservoir in step 7 of Bone’s post. Just make sure to use some loctite when putting them back on.  Vibration like to make bolts come lose and those are some you don’t want coming out. Also make note of there direction the have an arrow that should be pointing forward. Aside from all that you will be more than fine following JimmyBone’s guide. I might be missing a couple steps since this is all from memory, but I’m sure someone will chime in, if I have.
Regards
