Oil Overfill?
I had my oil changed and checked the dipstick a bit later and the level was about 1/8 inch past the top orange plastic. Too full? Danger danger??!!
overfull CAN be a problem.
Go back and have them drop some out.
Before you do though… and im just throwing this out there. But are you sure the car is 100% level when you check it? If its inclined it will throw the reading off.
Yeah, checked in my garage. Pretty level.
Thats probably going to be ok. There is a good amount of wiggle room there. More isn’t too bad. Too much can cause PCV issues. At the amount your talking about I wouldn’t be too worried.
Cool.
Nicht Uberfullen!
http://t3.gstatic.com/images?q=tbn:ANd9GcT4MPJ9rPl3PGBJA9Pjf2f_aqoi3dKMDezAvTpOufrdbnEwkjmrLVZUXTb5
for sure. Over filling can be a little hard on the PCV system. If you go too far.
Being overfull on oil really hurts the pre-cats but the OP is catless so it is less of an issue.
