oil pan surprise
Usually when you see something along that lines its a com issue on the car body side. Check the OBD connection on the body side. Also pull the carpet and check the body control module to see if there is anything that stands out. From time to time if you had the weather tray out water can get down in there and that can cause all kinds of issues. Water or loose wires are usually the first thing to look for.
Its usually a good rule of thumb. Its great to hear the car is up and running well.
OBD port looks fine as far as I can tell by looking at it, no broken or corroded pins or anything like that. I’m not sure what you mean by body control module, where under the carpet is that located?
