Non-VW Certified Oils
The following oils are not certified by VW to run in our engines. However, they are very high quality lubricants that meet or exceed VW’s specifications. If you have an Audi warranty to worry about, it may not be a good idea to run these since Audi may see it as a reason to void your warranty upon motor failure.
AMSOIL European Car Formula 5W-40
price: ~$10/qt
100% synthetic
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 13.7
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 82.2
Viscosity Index (ASTM D-2270) 171
Viscosity CCS, cP @ °C (ASTM D-5293) 5171 (-30)
Flash Point °C (°F) (ASTM D-92) 230 (446)
Fire Point °C (°F) (ASTM D-92) 248 (478)
Pour Point °C (°F) (ASTM D-97) -43 (-45)
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 8.9
Four Ball Wear Test (ASTM D-4172B @ 40 kg, 75°C, 1200 rpm, 1 hr), Scar, mm 0.44
Total Base Number 8.0
HTHS (cP) (ASTM D-4683) 3.8
5000 Mile UOA:
http://i.imgur.com/iyxe0.png
Red Line 5W-40
price: ~$10/qt
100% synthetic ester-based
API Service Class SM/SG/CF/CJ-4/CI-4
Viscosity Grade SAE 5W40
Vis @ 100°C, cSt 15.1
Vis @ 40°C, cSt 94
Viscosity Index 170
CCS Viscosity, Poise, @*C 55@-30
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 250
Flash Point, °F 480
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 6
HTHS Vis, cP @150°C, ASTM D4741 4.6
Renewal Lubricants Bio-SynXtra 5W-40
price: ~$10-15/qt depending on quantity purchased(1qt, 1gal, 5gal)
100% made with some crazy magic biobased shit(heh), was originally formulated for the 4.2L RS4 motor to help with the fuel dilution and carbon buildup issues
Specific Gravity @ 15.6°C 0.895
Viscosity @ 100°C 15
Viscosity @ 40°C 84.3
Viscosity Index 188
Flash Point (COC) 235°C
Pour Point -40
CCS @ -30°C, cp Max – 6,600
MRV-TP1 @ -35ºC, cP 15,000
Yield Stress, Pa None
HTHS @ 150º C, Apparent Viscosity, cP >3.7
NOACK Volatility % max 1h at 250°C 9
Motul 300V 5W-40
price: ~$15/qt
100% synthetic double ester-based
Viscosity grade SAE J 300 5W-40
Density at 15°C (59°F) ASTM D1298 0.905
Viscosity at100°C (212°F) ASTM D445 13.8 mm²/s
Viscosity at 40°C (104°F) ASTM D445 80.8 mm²/s
Viscosity Index ASTM D2270 176
HTHS viscosity at150°C (302°F) ASTM D4741 4.51 mPa.s
Pour point ASTM D97 -36°C / -33°F
Flash point ASTM D92 216°C / 420°F
TBN ASTM D 2896 10.9 mg KOH/g
