Opinions on S4 compression result's
Hey guys, I recently took my b6 S4 to a local VAG shop where I had them preform a compression test. The results all showed compression between 132-151. Other than the one cylinder at 132, all others showed between 140-151.
I spoke with Brian (Wolfs4) via text message a little and he referred me to this [URL] http://audirevolution.net/forum/index.php?topic=727.0 /URL] . I asked if they did the compression test wet or dry, and they said it was don’t by driving the car then doing it with the motor still warm. Would this give the same result as adding oil the the cylinders?
A little background on the car, its a 2004 and I’m just a hair under 124,000 miles. The car will burn about a qt of oil every 1200-1400 miles, I just now did spark plugs and new PCV also I change the oil every 5k with Liqui Moly . For what its worth I average about 270-300 miles per tank and about 19-21mpgs running 93 octane.
I would just like to get an idea on where my motor stands health wise. I know the numbers aren’t excellent, but I’d like to get the AR communities opinion. Thank you all in Advance, Nick!
