So i recently bought this car and talking to the previous owner he was telling me the car was tuned for 22 psi tapering to 19 towards redline. This is on a VAST tune. Seeing how i tried to different tunes and they both do the same i am tending to believe i have a hardware issues vs a software issue. Description below.
My troubleshooting:
Round 1.
I am peaking 26-27 psi according to the boost gauge and this thing seems pretty accurate showing 20 mm/Hg vacuum at idle and resetting to 0 with engine off. Also i can feel the boost coming in as the gauge starts indicating it from 0 and on.
No vaccum leaks, idle is rock solid, passed SMOG today. Scanned with VAG COM and no codes are present. Checked for an MBC and none is present. Gauge is a 30psi JHM boost gauge. N75 is said to be new(can i check it?). Boost builds gradually and stays solid until you take your foot out of it.
Round 2.
Swapped files to a different tune made for Franken turbos. This is also a 22 psi file, that i was able to borrow from a local member for SMOG purposes.
Same thing here … this one spikes to 28-29 psi and would probably keep going if i were to keep my foot in it. I even blew off an intercooler hose today.
No vaccum leaks that i can detect, idle is rock solid, passed SMOG today. Scanned with VAG COM and no codes are present. Checked for an MBC and none is present. Gauge is the same as above. No other changes to the car.
Question:
so for all you gurus … what could my issue be? i am kind of scared to drive it this way because i might be pushing the stock block too far
i have a vagcom so i am all ears as to how and what i should check to find the root cause for this.
Also i would rather not have to add an MBC in parallel.(most of the other threads on the subject suggest this but im not too keen on it)
thanks in advance for all your valuable suggestions.
i’m a fresh transfer from the BMW world.
