Oxygen Sensor Replacement B3S1 2008 S6 v10
This thread says B3 S1 can be changed in car.
JimmyBones
* Audi Tech *
7d
Entirely depends on your budget and mechanical ability.
  1. Oxygen sensors depending
    1a. Three of the O2s are unreachable with the engine still in the car. They are bank two (cylinders 4 and 5) sensors 1 and 2 along with bank four (cylinders 9 and 10) sensor 1.
    1b. Three of the O2s are annoying to replace with the engine still in the car but doable. They are bank 1 (cylinders 1-3) sensor 2, bank 3 (cylinders 6-8) sensor 2, and bank 4 (cylinders 9 and 10) sensor 2.
    1c. Two of the oxygen sensors are extremely easy to replace. They are bank 1 (cylinders 1-3) sensor 1 and bank 3 (cylinders 6-8) sensor 1.
Does anyone have a write up on bank 3, sensor 1?
I haven’t looked at on the lift …yet.
Thanks!
here are my fault scans
Tuesday,19,January,2021,18:16:24:27541
VCDS – Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
            Address 01: Engine       Labels: User\07L-910-552-BSM1.lbl
Control Module Part Number: 4F1 910 562 A HW: 4F1 907 552 B
Component and/or Version: 5.2L V10/4V FSI ÂŞ0010
Software Coding: 01050009190F0160
Work Shop Code: WSC 26110 444 124922
VCID: 23459C08E2BE6D9C3F-8076
1 Fault Found
P1923 - 008 -
Freeze Frame
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192604 km
Time Indication: 0
         Freeze Frame
                RPM: 0 /min
                Load: 0.0 %
                Speed: 0.0 km/h
                Temperature: 109.0°C
                Temperature: 41.0°C
                Absolute Pres.: 1000.0 mbar
                Voltage: 11.684 V
Readiness: 0000 0000
            Address 11: Engine II       Labels: User\07L-910-552-BSM2.lbl
6 Faults Found
004229 - Mixture Regulation; Bank 4; Range 1
P1085 - 004 - Lean Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192495 km
Time Indication: 0
Date: 2021.01.18
Time: 13:21:38
         Freeze Frame
                RPM: 593 /min
                Load: 19.6 %
                Speed: 0.0 km/h
                Temperature: 74.0°C
                Temperature: 33.0°C
                Absolute Pres.: 1010.0 mbar
                Voltage: 14.224 V
012809 - Oxygen (Lambda) Sensor B3 S1
P3209 - 002 - Signal too Slow - Intermittent - MIL ON
Freeze Frame
Fault Status: 10100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192514 km
Time Indication: 0
Date: 2021.01.18
Time: 16:14:25
         Freeze Frame
                RPM: 1519 /min
                Load: 48.6 %
                Speed: 70.0 km/h
                Temperature: 102.0°C
                Temperature: 30.0°C
                Voltage: 14.224 V
012920 - Linear Oxygen (Lambda) Sensor B3 S1; Pump Current Wire
P3278 - 008 - Open Circuit
Freeze Frame
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 192518 km
Time Indication: 0
Date: 2021.01.18
Time: 16:17:48
         Freeze Frame
                RPM: 1394 /min
                Load: 17.6 %
                Speed: 52.0 km/h
                Temperature: 108.0°C
                Temperature: 33.0°C
                Voltage: 14.224 V
P0300 - 001 - - Intermittent
Freeze Frame
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - Intermittent
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
6 Faults Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192495 km
Time Indication: 0
Date: 2021.01.18
Time: 13:21:38
         Freeze Frame
                RPM: 593 /min
                Load: 19.6 %
                Speed: 0.0 km/h
                Temperature: 74.0°C
                Temperature: 33.0°C
                Voltage: 14.224 V
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192514 km
Time Indication: 0
Date: 2021.01.18
Time: 16:14:25
         Freeze Frame
                RPM: 1519 /min
                Load: 48.6 %
                Speed: 70.0 km/h
                Temperature: 30.0°C
                Voltage: 14.224 V
Freeze Frame
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 192518 km
Time Indication: 0
Date: 2021.01.18
Time: 16:17:48
         Freeze Frame
                RPM: 1394 /min
                Load: 17.6 %
                Speed: 52.0 km/h
                Temperature: 33.0°C
                Voltage: 14.224 V
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
000774 - Cylinder 6
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
000776 - Cylinder 8
Freeze Frame
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 192520 km
Time Indication: 0
Date: 2021.01.19
Time: 07:09:20
         Freeze Frame
                RPM: 670 /min
                Load: 33.3 %
                Speed: 3.0 km/h
                Temperature: 44.0°C
                Temperature: 18.0°C
                Voltage: 13.716 V
Well… I only have the German SSP376 for Audi 5.2l V10.
They only write about 2 banks. Left and right 5-cyl. banks. But if we can agree that bank 1 is cyl. 1-2-3, bank 2 is 4-5, bank 3 is 6-7-8 and bank 4 is 9-10 then it should be as follows…
Seen from inside the car looking out towards motor…
Left side is cyl. 6-10 where 6-7-8 goes into cat. #3 with O2 sensor 3 G285 bank 3 before cat. and O2 sensor 3 G287 bank 3 after cat. Cyl. 9-10 goes into cat. #4 with O2 sensor 4 G286 bank 4 before cat. and O2 sensor G288 bank 4 after cat.
Right side is cyl. 1-5 where 1-2-3 goes into cat. #1 with O2 sensor 2 G108 bank 1 before cat. and O2 sensor 2 G131 bank 1 after cat. Cyl 4-5 goes into cat. #2 with O2 sensor 1 GG39 bank 2 before cat. and O2 sensor 1 GG130 bank 2 after cat.
G39, G130, G286 - engine out.
G131, G287, G288 - difficult
G108, G285 - easy
Bank 3, sensor 1 is the G285… the easy one before cat. #3 (left most furthest back cat.)
I can print/patch and scan the images of the setup later if you want?
I would agree that we are talking about G285.
I would love the print out.
you can email it to me if you’d like.
drewwattles@sbcglobal.net
thanks!
Sorry… got busy. I have sent an email.
Have a nice weekend :smile:
Regards Kim
Got’em! thanks!
This was a legit 10 minute job. I put the car on stands, removed a crossmember (4 bolts, 16mm socket) and then removed the 02 sensor (China Freight offset O2 socket).
New 02 in, crossmember bolted in and car on the ground. No more CEL.
Hopefully I can get it smogged this week…
You mind posting that on her or sending me that as well?
Not sure if I’m allowed to post it here… I have scanned the SSP, printed the 2 pages, “spliced” them together, corrected a couple of textual errors and scanned the important parts… but nevertheless I guess Audi’s copyright still stands :thinking:
I can however send it to you as well… mail?
I emailed the pages you sent me.
:+1: :smile:
